Jumps seats to bench in 90's - Defender Source
Old September 8th, 2010, 05:14 PM
Dustin
Dustin Chase
2006 HSE
I am looking for a 95 to 97 d90. Most I am finding have the jump seats. How hard is it to put in a bench after I buy it.
thanks
Dustin
Old September 8th, 2010, 05:23 PM
bjf's Avatar
bjf
barry f
94 ST #395
super easy. The hardest part is finding the actual seat and seat belts.
------ Follow up post added September 8th, 2010 02:25 PM ------
I should say it depends, if you are looking for a ST or SW. Slightly harder in a SW as you need to locate the mounts for the shoulder harnesses (came in POE) trucks but still doable.
Old September 8th, 2010, 07:22 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Are the SW mounts even available anywhere? I see that ECR makes them for in-house work.
-Ren Ching
Old September 8th, 2010, 10:38 PM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
bench seat
Jeep rear bench is a drop in and the brackets are easy to make. the seat belt mounts are not hard either. It's only an issue if you want a factory setup which is not hard to find just expensive.
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
Old September 8th, 2010, 10:54 PM
bjf's Avatar
bjf
barry f
94 ST #395
The POE trucks had the mounts. I am sure the part number can be found.
Old September 9th, 2010, 12:34 AM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
As a seatbelt suggestion......
http://www.brookwell.co.uk/item/4848...nted-seat-belt
These are usually used for the "center" seat position when you want an over-the-shoulder three point harness but don't have access to the bulhead.
I plan on mounting a bench in the back and then installing these belts.
I'm installing the bench facing to the back.
Old September 9th, 2010, 11:59 AM
Please locate it.
Old September 9th, 2010, 01:00 PM
bjf's Avatar
bjf
barry f
94 ST #395
should be on part cd. let me look
Old September 9th, 2010, 01:42 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
a non-fold and tumble CJ seat is what I'm going to use when I eventually go down this road
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
90, bench, seats
Land Rover Waterproofs for Bench Seats newfD90 For Sale - Parts 1 March 29th, 2006 09:58 AM
Rear Bench Seats (Pair) roverboy For Sale - Parts 2 November 16th, 2005 10:28 AM
Looking for inward facing seats, will trade forward facing bench NASD90 Wanted 5 August 11th, 2004 11:12 AM
FS: Four SW Jump Seats from 95 D90 DJ Menasco For Sale - Parts 4 December 19th, 2003 12:28 AM
Inward Facing Rear Bench Seats pat90 For Sale - Parts 0 November 1st, 2003 03:16 PM
