Jumping fuel gauge - Defender Source
Old January 31st, 2015, 11:32 PM
mlorman's Avatar
mlorman
Mark Lorman
95 ST #2782
Jumping fuel gauge
My 97 fuel gauge bounces all over the place. Ground? Sender? Can you replace the sender without buying a new pump?
Old February 1st, 2015, 12:09 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Well, the fuel sender gets its ground from the infamous K108, the big ground lug on the passenger side of the bulkhead in the engine compartment, like 75% of the truck.
If you aren't seeing any other electrical issues, I would assume the sender is going bad.
I believe it's an integral unit.
Old February 1st, 2015, 12:57 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
On the 1997, The fuel SENDER gets grounded on the right side of the transfer case, the fuel GAUGE gets grounded where Neil says in post # 2
The fuel level sender (in the tank) is NAS specific (I tried an RRC & it did not show the correct level)
The only way I know of to get a correct NAS sender is to buy the whole fuel pump/ sender assembly, and it's not cheap!
Old February 1st, 2015, 09:25 AM
mlorman's Avatar
mlorman
Mark Lorman
95 ST #2782
Jumping does not appear to be related to the vehicles movements. It pretty much jumps all the time.
Old February 1st, 2015, 11:14 AM
I would guess lose wire or faulty ground. The fuel gauge has 3 wires. A hot as battery voltage reference. A ground and a signal from the fuel tank. Given the fuel tank signal is the hardest to deal with if trace out the other two and make sure they are clean and well connected at both ends.
Old February 1st, 2015, 12:29 PM
navydevildoc
Neill Thornton
You know, that's what I was going to say, but to be sure my blonde ass wasn't giving bad gouge I went and looked at the wiring diagram and it showed the ground going all the way back to K108.
I just went back again and of course you are right, it was the gauge and not the sender I was looking at. I should have just stuck with my instincts... go figure.
Old February 1st, 2015, 12:58 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
My fuel needle has always flopped around, 17 years worth.
My latest woonky needle problem was because the connector at the tank was loose.
fuel gauge ohm range naeirie Defender Technical Discussions 35 September 6th, 2017 02:49 PM
Speedo Jumping - Odometer is OK Krna Defender Technical Discussions 4 October 24th, 2015 02:03 PM
Defender 110 SW rebuild (jumping into the deep end) Wilboro Truck Build-up's & Restores 72 June 16th, 2015 05:15 PM
Fuel pump and fuel gauge relationship question - troubleshoting... arbik Defender Technical Discussions 1 September 19th, 2006 02:31 PM
Help wth Fuel Gauge (that works sometimes) ToyCrusher Defender Technical Discussions 14 October 20th, 2004 08:43 PM
