jumper cables - Defender Source
Old February 28th, 2005, 03:19 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
jumper cables
I was looking in a catalog and found those jumper cables that just plug into the lighter socket. Has anyone used these, and do they work. According to the directions you just plug into both lighter sockets wait 5 minutes and start the vehicle. I think they would work as a back up set for me after putting new seats in and losing access to the battery compartment.
Old February 28th, 2005, 03:58 PM
mrmuddy
John Cranfield
1989 90
Don't even bother. To get sufficient charge into your battery to start will take ages, longer than most people are prepared to wait so the temptation is to try to start while still connected with the tiny little wires. This results in melted wires and blown fuses at best or a fire at worst.
Old February 28th, 2005, 04:01 PM
Yup sounds like a gimmick to me! To crank most starters you need 100 to 200 amps, the cig lighter in most cars is limited to between 5 and 15 amps, it would take an hour or more to get any kind of charge that way.
Old March 1st, 2005, 06:47 AM
ronward's Avatar
ronward
Redsrover
None - sadly
True these 12v outlet starters are for trickle charging the reduced battery, not side of the road jump starting. Although I once jumped a Suburban from my Disco I once. Took about 5 to 10 minutes sitting there connected, then she fired right up.
Anything is possible, with the right tools...
Old March 2nd, 2005, 03:11 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
Awful idea. But if you do get it, unplug the thing before trying to start the dead vehicle. I can't imagine trying to draw starter current through the wires running to the lighter socket. If you're lucky, the worst that will happen is that you'll blow a fuse. If unlucky, the wires get hot enough to degrade their insulation. 'not something I'd want to do to my vehicle, in the interests of reliability.
If for some reason you don't want to access the battery compartment for jumping, I'd suggest installing a heavy-duty connector in the engine compartment that the jumper cable can be connected to: http://www.warn.com/truck/accessorie...t_cables.shtml
Old March 4th, 2005, 08:50 PM
artm
Arthur Maravelis
97 SW
No way you should be using the lighter socket for any serious amperage. I once had a compressor draw too much and burn the wiring - not a pretty sight waiting for a fire to catch!
Having the battery under the seat can be very inconvenient so run a heavy line to the engine bay and connect to that. You can even install a fuse box there for future use.
How does everyone route their winch cables JackW Defender Technical Discussions 10 September 12th, 2008 11:15 AM
Quick Connects for winch / jumper cables trislerjw Smaller Projects 3 January 10th, 2007 01:26 PM
cables to heater box ? mattdh Defender Technical Discussions 3 March 6th, 2006 09:33 AM
H2 stump jumper... norros Misc. Chit-Chat 1 December 22nd, 2004 11:30 AM
Speedo Cables scot Defender Technical Discussions 3 October 29th, 2003 01:21 PM
