Jump Seat wheel arch bolts - Defender Source
Old May 18th, 2011, 11:21 AM
brettm's Avatar
brettm
Brett
97 D90-SW, Arles +4.6
I'm installing my jump seats for the first time... couple of questions:
- what do folks use to protect the the mounting bolts that protrude into the wheel arch? seem like a prime candidate for rusting shut and never being opened again. cake them in grease?
- any tips for holding the damn bolt head tight above while you fasten the nut from inside the wheel arch? or is it normally a two-person job? my "socket spanner duct-taped down" technique seemed a little amateur - there must be a better way...
Old May 18th, 2011, 11:43 AM
Mine didn't have any rust. there's good draining there. I had to use vice grips in side, but you can actually hold both ends with the window open on most of them. 2 persons make it much easier.
I put rivnuts in for all those bolts. life changing experience....period. nows the time if ever to do it.
Old May 18th, 2011, 01:21 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
I used stainless steel bolts
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old May 18th, 2011, 03:42 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Me too, with a Zinc washer and Neoprene washer (on the outside), lock washer and nut on the inside.
I installed them with the bolts facing up and had wifey tighten them from inside the cab which I held with a spanner below.
I used 5/16 bolts (1/2" heads) by ~2.5" long.
I can post a pic from below if you'd like too.
good luck.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
bolts, jump seat, wheel
female short seat belts for jump seats Marc Weinstein Wanted 0 March 24th, 2005 08:54 PM
Forward facing jump seat rvrsrvc For Sale - Parts 3 November 18th, 2004 08:21 PM
Removing Seat Track Bolts! JimC Defender Technical Discussions 5 November 5th, 2004 03:15 AM
Wheel Arch Protectors/Eyebrows boshea Defender Technical Discussions 2 June 29th, 2004 11:28 AM
beat up broken trashed jump seat dnewman9 Wanted 0 June 27th, 2004 12:38 PM
