jump seat backrest frame differences - Defender Source
Old May 25th, 2011, 03:32 PM
I have two kinds of jump seat backrests and I am wondering if anyone is familiar with these differences and can tell me if perhaps mine were installed wrong or meant for another application. If you look at these pictures the one on the left with the black trim is what I have and the one on the right are a different style.
The black one has a curved leg with a higher top mount point. As installed, keeping the backrest essentially vertical puts the mount point above the tub capping and they used a little extender/strap to mount them. If you forced the feet all the way into the corner of the tub, the mount does lower to where you might be able to bolt it to the capping but the backrest tilts forward - surely not right.
On the other hand the grey one seems to fit perfectly and even has a slot instead of a hole to ease installation. It seems like a better fit in general for the defender.
Is the black one perhaps meant for some other model, or installed wrong? I don't want to change it since I already have holes for their current location, but I am curious about the difference.
ID:	39075   Click image for larger version
Originally Posted by pendy
I'm here for the D's
Old May 25th, 2011, 03:41 PM
bjp
Brent
1995 D90
The grey one is exmoor.
Old May 25th, 2011, 04:05 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
The jumpseat with the "bent" arms is from a 110, the other from a 90.
Exmoor sucks, don't buy that stuff.
What tree?
Old May 25th, 2011, 04:08 PM
Thanks Carey
So does a 110 have lower wheel arches or higher cappings than a D90? I would not have thought so. Or put another way, do the upper mounts mount directly to the capping or a bit higher on a 110?
thanks,
charles
Old May 25th, 2011, 04:44 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Strange, my NAS110 ones are bent like the first picture, but the holes for the capping support are slotted and look exactly like the other ones. On a NAS110 the rear mounts to the capping through the window trim, just below the sliding windows.
Old May 25th, 2011, 10:01 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
my jumpseats, all sourced from NAS 90's have the one with the straight arms.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old May 26th, 2011, 08:23 AM
Grover's Avatar
Grover
Mine are like the one pictured on the w/ right straight supports, genuine LR units.
Old May 26th, 2011, 08:44 AM
Mounted with little straps/extenders down to the capping, or directly to the capping?
ac, jump seat
looking for seat frame jcasteel Wanted 0 July 19th, 2005 09:55 AM
female short seat belts for jump seats Marc Weinstein Wanted 0 March 24th, 2005 08:54 PM
Forward facing jump seat rvrsrvc For Sale - Parts 3 November 18th, 2004 08:21 PM
beat up broken trashed jump seat dnewman9 Wanted 0 June 27th, 2004 12:38 PM
Jump Seat Straps Hammertime Wanted 1 January 19th, 2004 04:49 PM
