Jonesys Gearbox replacement - Page 3 - Defender Source
Old October 11th, 2015, 09:03 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Originally Posted by Jonesy
I will try to get my sorry arse to his place at 8am and get into it.
Figuring 4 hrs out and 4hrs in so hopefully (touch wood) will be driving it at 5pm with an hour for lunch.
So..... Reality time check now?
Start time was 9:30am and finish time was 1am?
That's be 11:30 of work including 2H for lunch and dinner (and whatever else happened under the truck based on the pics posted, there was a lot of that...).
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 11th, 2015, 09:27 AM
87 D110 (Ruby)
Yep - So what was supposed to be an 8hr job, became a little longer. I think the standing around talking about what to do after the gearbox was assessed was a loss of a few hours, but the beer and Pizza was good. But everyone felt like it took too long....I mean at one point we were hoping in Mikes truck for a 4hr Drive to Roberts to pick up his R380 Shorty. Until some cooler heads (Jeff & Grumpy Bill) prevailed and said - naaaah, she'll be right mate, don't worry about circlips
Charles will tell you it was because of all the extra cleaning we had to do, of my dirty truck - or that may just have been him needing the "whaaaaaambulance" .
But I will tell you all it was because of all Mikes farts all afternoon bring tears to our eyes - that boy has some bad seals
Old October 11th, 2015, 01:17 PM
Yeah, next project is a new rear main seal for mike.
I don't think estimating is our strong suit, but pretty much everything that could go wrong did, and that damn truck was filthy!
Originally Posted by pendy
I'm here for the D's
Old October 11th, 2015, 03:49 PM
And don't forget some diff setting up as well .
Old October 11th, 2015, 04:02 PM
wanabewheelin's Avatar
wanabewheelin
Michael Sword
1989 110 200TDI, RHD
Or a 200tdi swap . . .
Old October 11th, 2015, 05:02 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Congrats Jonesy! What an epic come from behind WIN! Eff'n impressive how that situation was turned around through pure will.
Old October 11th, 2015, 05:35 PM
87 D110 (Ruby)
Thanks Clay - and thanks for your time helping in the am...you missed pizza beer and Mike's leaky seal...epic stuff
Old October 11th, 2015, 05:46 PM
87 D110 (Ruby)
Steps
Ok - Figured I would post up...
1. CLEAN Vehicle underneath, all nooks and crannies - with a toothbrush if Galpin is involved
2. Crossmember comes out
3. Exhaust comes off
4. Disconnect driveshafts at LT230 - not at Diffs
4. Disconnect LT230 linkages and wiring - sorta depends on vehicle - but Defender ROW have one wire for diff lock
5. Disconnect hand brake cable - take off the cable, not the bracketry (mistake we made)
6. Remove PTO cover (round cover) from LT230 and remove input gear - should pull out easy - inspect bearings & teeth - ensure all looks good
7. Unbolt LT230 and lower - a few niggly ones, but not too bad - only about a 70lb lump, so can be handled singly
8. Unbolt LT77 mounts and ring bolts to engine with it supported by trans jack - keep a jack on/under engine - it helps with removal.
9. undo Clutch cover and take off
10. remove clutch plate
11. unbolt flywheel (if that is hard then rebolt the cover and use it to beat on and lever the flywheel out - it can be sticky (assuming you are replacing the cover of course)
12. Inspect the main seal - leaks? Replace - no leaks - leave it
13. Take off the motor mount brackets from the frame - easier to reposition everything
Replace all parts with new ones in opposite order.
Note when reassembling the gearbox and TCase - put them together on the ground and ensure serviceability, set up linkage etc to ensure it all works. Then either take off the TC or if you feel tough and have enough hands put them both up together.
It think I got everything - others may post up corrections - additions
Old October 11th, 2015, 07:00 PM
You guys are awesome.
Thanks for sharing the details of the project, well, most of them anyway
LT 95 gearbox..do I have to remove gearbox from truck to replace reverse idler shaft? Ncmike Series Technical Discussions 3 April 13th, 2014 03:33 PM
I've broken my gearbox!!! mikeslandrover Defender Technical Discussions 6 May 29th, 2006 05:04 PM
gearbox help !! mud_man Defender Technical Discussions 12 November 28th, 2005 12:29 PM
'97 D90 external gearbox cooler pipes. kiphartzell Defender Technical Discussions 0 March 29th, 2005 11:51 AM
