Jerry Can Mounting Ideas - Page 2 - Defender Source
Old January 22nd, 2015, 08:09 AM
broadstone's Avatar
broadstone
'84 CSW 90 '74 NADA III '97 CSW 110
I always wanted to fabricate a jerry can mount that allowed as much of the actual mounting to be concealed. I finally did it and was very happy with the results. It actually kinda locks in place but the band is of course to be sure it does not fall out or get stolen.
ID:	111711   Click image for larger version
Old January 22nd, 2015, 08:15 AM
So when you want to lower the tailgate, doesn't that want to make it come crashing down against the chains?
Old January 22nd, 2015, 09:18 AM
broadstone's Avatar
broadstone
Only if you let go of it when the can is full. If you can handle a full jerry can you can handle the tailgate I suppose, and since it is only me opening or closing it that is not a concern. Can is only full on long trips which I have done once.
Old January 22nd, 2015, 07:07 PM
coffee's Avatar
coffee
John Oates
1993 NAS Defender 110 #367/500
Originally Posted by Wolf Fabrication View Post
Check out Rotopax cans. They are plastic, modular, and have a lot of mounting options. They are 2 gallon cans that are stackable and nice and thin. Here are a few pics of mine. They mount through a center hole with a lockable mount too.
Rotopax are the best. What is that hose coming out the back?
Old January 22nd, 2015, 07:13 PM
coffee's Avatar
coffee
John Oates
Rotopax also offer water jugs (atop)
Old January 22nd, 2015, 07:14 PM
drdread's Avatar
drdread
AL
'94 NAS 90 SW
Rotopax look awesome. Just don't understand how they could mount on a ST in any permanent way.
1994 Silver DEFENDER 90 NAS SW
Old January 22nd, 2015, 08:02 PM
coffee's Avatar
coffee
John Oates
You can get extended mounts (designed for multiple pax) and mount one or more to your spare. They also offer a keyed mount. I think the best size is the 1.75 gallon, but there are lots of sizes and configurations. I use these and NATO cans, which I agree are fumeless, just beware opening them if the have been in the sun - I learned my lesson the hard way several years ago by underestimating the pressure....
Old January 22nd, 2015, 08:48 PM
DefenderMd's Avatar
DefenderMd
Ben
87 defender 110 3 door
I like my exmod lockers... whooo 80l of fuel stowed easily.
If I had to carry extra, I think the roof rack stowage is the most reasonable.. but like others said. Nato 20l cans don't leak, don't stink, don't pour easily. But ya can't beat em. I keep 120l sitting around in case I need to fill my boiler tank, or the rover. If ya search around, you can find them used for a decent price. Buy some new gaskets if you need.
------ Follow up post added January 22nd, 2015 08:55 PM ------
AND/OR.. difficulty in opening them if filled warm and now sub freezing. had to use the box end wrench I use for my tire iron to pop open a couple a couple weeks ago. Also... a few of my old ones, the lining is flaking off. With a sedimenter, filler neck screen, fuel filter, it shouldn't be a problem, but i've tried to rinse out as much as I can. But when I say "older" I mean, 1960s era.
Old January 22nd, 2015, 09:30 PM
toad's Avatar
toad
Cutter
Can anyone recommend a decent spout for the NATO cans? I have one from RN that is worthless, more gas on me then down the spout. Sorry for the hijack. I carry mine in the back with ratchets, I'll probably move it to the roof rack if there are kids in the truck.
Old January 22nd, 2015, 09:31 PM
drdread's Avatar
drdread
AL
'94 NAS 90 SW
Found a bunch on eBay
Old January 22nd, 2015, 09:46 PM
coffee's Avatar
coffee
John Oates
I have these from Atlantic British and they work well.
http://www.roverparts.com/Parts/GJC002
Old January 22nd, 2015, 10:06 PM
DefenderMd's Avatar
DefenderMd
Ben
They all have to be pretty much the same. Regardless of where ive seen them and what brand they had on the , theyve all been the same. You MUST support the can when pouring. You cannot rest the spout on your filler hole and use it as a fulcrum-- It will leak. The vent pretty much has to be the way it is, which can allow for some slight spillage in some circumstances.
ebay 3/$20.
Old January 23rd, 2015, 02:33 PM
toad's Avatar
toad
Cutter
Ok, yes I've seen the ones on eBay, they are just like what I have. Maybe I just have a dud, which isn't surprising given the price. I wasn't sure if there was a source for a better quality unit. I'll roll the dice again.
Old January 23rd, 2015, 08:03 PM
DefenderMd's Avatar
DefenderMd
Ben
how did it fail?
There;s not really a way they can, unless the gasket is bad or they're damaged
They either fit or they don.t
Is your can a real nato can?
Old January 23rd, 2015, 09:22 PM
boswalt's Avatar
boswalt
Brian Oswalt
1988 exmod 110
I had NATO cans but they leaked everytime I used them. switched to Scepter and haven't spilled a drop yet. Place just north of me sells them for $55 each. I buy one or two everytime I go up to visit the inlaws......for water of course
mount
skid plates, jerry cans... Rover- Girl Wanted 3 July 24th, 2005 09:00 PM
Jerry Can Mounting? OCD90 Defender Technical Discussions 13 August 16th, 2004 07:03 PM
Windscreen ideas Mike Hippert Misc. Chit-Chat 40 July 9th, 2004 02:38 PM
rear bench seat for D-90 SW GriffCA Defender Technical Discussions 22 June 2nd, 2004 01:40 AM
CB mounting ideas flippedrover Defender Technical Discussions 21 March 29th, 2004 11:22 PM
