JB weld a viscous drive? - Defender Source
Old September 22nd, 2009, 05:07 PM
wantone
Rick Thompson
94 ST #1222
Anybody ever just JB weld a viscous drive when is shot? any problems if one did it? I tried a search and some said drill in a screw, just thought this would be simple. First post to the forum! Thanks for the help, awesome site!
Old September 22nd, 2009, 05:16 PM
well, no viscous on defenders unless you are driving a conversion ( I know of one ) but I'm not sure where you would put the JB. Bolt trick would work if there is sufficient space in the casing but the question is WHY?
Old September 23rd, 2009, 12:07 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
He is talking about the fan viscous
yes, two carefully placed sheet metal screws will get you home
Old September 23rd, 2009, 09:34 AM
wantone
Rick Thompson
94 ST #1222
thanks
yes the viscous fan, my apologies . is there a problem screwing solid for the long term? i checked the fan when it was cool and warm, there was a bit of resistance, but it was the same amount whether cold or hot. The truck does not run warm, I just want to keep it that way, know what I mean?
Thanks so much guys you are all such a huge help!
Old September 23rd, 2009, 09:47 AM
I have seen a fan Clutch with JB Weld on a 94 D90... My buddy still drives his truck with it.
viscous drive replacement SIIA109 Defender Technical Discussions 14 December 1st, 2008 02:13 PM
Drive line problems HELP D90user Defender Technical Discussions 4 February 17th, 2005 10:19 PM
weld on motor mounts pendy For Sale - Parts 3 September 8th, 2004 03:10 AM
drive line/OME springs flippedrover Defender Technical Discussions 2 May 3rd, 2004 10:23 PM
