JB Weld - Defender Source
Old April 11th, 2010, 12:24 PM
aosias's Avatar
aosias
Alexandra
1995 D90
JB Weld
I am looking to tack weld the nuts to the plates and then the plates to the truck for my rear bench seat mounts. I hate needing a 2nd person to help me install the feet and remove them and the dog hates having them in the middle of the truck bed.
Would something like JB Weld be sufficient to hold all this together during the removal and installation process? I will replaced the bolts each time so I'm not expecting to be able to drive around with just the plates JB welded to the truck. I can't weld, don't have access to stuff to weld.
Old April 11th, 2010, 01:45 PM
bjf's Avatar
bjf
barry f
94 ST #395
JB weld is pretty strong but I would tack weld or have the bolts tack welded to the plates. Then use jb weld to hold to truck. I think if you remove the bolts one at a time with replacing one beofre removing the second this should be fine.
learn to weld.
Old April 11th, 2010, 02:55 PM
The making nut plates thing I understand, but you're not going to be able to weld the steel nut plates to the aluminum tub...
Anyone can make the plates you need pretty EZ if you just go to a sheet metal shop, ornamental iron place, or maybe you even know a muffler place you don't mind asking. Buy the metal strips at HD/Lowe's, cut, drill, get the nuts you want, and then just ask someone to tack them in place. Paint them after they're welded up.
WRT to attaching it to the truck, if you must, just rivet them.
I wanna learn to weld RickM Defender Technical Discussions 17 November 18th, 2009 09:57 PM
JB weld a viscous drive? wantone Defender Technical Discussions 4 September 23rd, 2009 09:47 AM
Weld on Factory LR A bar.. mightymg For Sale - Parts 10 September 3rd, 2009 10:08 PM
someone to weld new rear xmember Gore Ranger Wanted 10 October 12th, 2006 08:59 PM
weld on motor mounts pendy For Sale - Parts 3 September 8th, 2004 03:10 AM
