JATE recovery rings - Defender Source
Old November 21st, 2015, 11:20 PM
MGPete's Avatar
MGPete
Pete C
'95 D90 SW
JATE recovery rings
I'm looking to better outfit my truck for this years Wintergreen Event (and others) and would like to get 1 or 2 of the JATE rings for front recovery points.
Looking for thoughts on whether getting the Genuine LR part at the significantly added cost is worth it over the aftermarket ones? $129 vs $39.
Also, is 1 enough or should I get 2?
Old November 21st, 2015, 11:23 PM
You want two. They need to be bridled as they are not very strong.
Old November 21st, 2015, 11:28 PM
Is there any difference between a Genuine one and an aftermarket one? I'm sure the aftermarket ones have accurate load ratings. You can never have too many recovery points, but one would probably be fine. I don't think any recoveries were even needed in the last two years at Wintergreen in the intermediate group.
------ Follow up post added November 21st, 2015 11:30 PM ------
I would think the Jate ring is stronger than the frame it is attached to, haha.
Old November 21st, 2015, 11:31 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Jate rings are next to useless, just think of where they are, under your Landy. you would be better off fitting recovery rings on the top of the bumper.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old November 21st, 2015, 11:39 PM
Keep in mind they were never intended as recovery points.
Old November 22nd, 2015, 09:34 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Jate rings used in the wrong recovery will be dangerous. If your front frame horn(s) are compromised, which you should assume are unless you remove the bumper and inspect it thoroughly, they won't hold. They were meant to be used as tie down points not recovery points.
Old November 22nd, 2015, 10:11 AM
genuine were forged, the aftermarket ones I have seen are just welded mild steel
Old November 22nd, 2015, 10:37 AM
MGPete's Avatar
MGPete
Pete C
'95 D90 SW
So what constitutes a good front recovery point with a stock front bumper and no winch?
For the rear, I was thinking about a hitch mounted shackle.
Old November 22nd, 2015, 10:44 AM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
A Dixon Bates is what I use.
Old November 22nd, 2015, 10:52 AM
MGPete's Avatar
MGPete
Pete C
'95 D90 SW
Nice, where does that bolt to?
Old November 22nd, 2015, 10:54 AM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
It bolts onto your paper thin bumper with a small backing plate behind it.
Stock bumper is useless, you should get something solid if you plan on using it for recovery!! Make sure whatever you end up doing ties into the frame a bit.
something like this:
http://www.pangolin4x4.com/land-rove...uct-6355337252
Old November 22nd, 2015, 11:22 AM
This is Trey's front setup. The bow shackles are attached to galvanized LR parts often found on military trucks. They secure with the same bolts that the bumper does, the bolts need to be longer of course and you want grade 8.
The bumper is actually one of the early 110 ones that the factory galvanized. Much thicker than later ones and still looks great 30+ years later.
The under bumper winch tray is also a factory part from a NAS 90.
Like this setup because it doesn't obscure the classic front end lines and the recovery points are as high as you can get them( and bolt through the frame) which is key if the culprit is mud.
The original hole for the keyed hood lock in the grill surround that very early 110's came with was used for the winch remote plug.
Name:	Treys front Bumper.jpg
Old November 22nd, 2015, 11:27 AM
IMO, it is not possible. The stock bumper is not strong enough to attach anything to. If you do not want an aftermarket bumper, a good choice is a military bumper. They have a built in central recovery point. If you can pickup a used one from someone that has installed a winch, you might get a good deal.
Old November 22nd, 2015, 11:34 AM
This is Trey's front setup. The bow shackles are atatched to LR parts often found on military trucks. They secure with the same bolts that the bumper does, the bolts need to be longer of course and you want grade 8.
I would be careful with that. The stock bolts are 10mm. With the leverage, those would be a bit too close to the edge. I would drill out for 1/2" bolts which is about 50% stronger.
Old November 22nd, 2015, 11:49 AM
You could look for an Ex MOD like this. http://www.defendersource.com/forum/...pin-66132.html
cover
Jate recovery rings Naplm00 Wanted 2 February 13th, 2015 06:46 PM
JATE rings (new) JBfoot For Sale - Parts 2 August 23rd, 2008 05:42 PM
skid plates, jate rings, tires, factory steps, factory sills draaronr For Sale - Parts 4 September 21st, 2006 09:47 PM
JATE Rings 1of40 For Sale - Parts 11 May 9th, 2006 02:18 AM
Jate Rings jabber For Sale - Parts 5 February 24th, 2005 12:51 PM
