I've broken my gearbox!!! - Defender Source
Old February 19th, 2006, 01:30 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
An hour or two into some splendid off roading today everything went pear shaped
Whilst descending a rather steep and ridiculously slippery hill I fetchet up with the bumper pressed rather hard against an oak tree.
A few spirited attempts at reversing out of this predigament seem to have destroyed reverse gear, well it won't stay in gear under any sort of power, even trying to hold it in with the gear lever doesn't help.
Only reverse gear is affected.
Is this going to be a new gear box job or is reverse gear relatively easy to get at?
Anyone out there got any experience with home gearbox rebuilds?
Mike Hammond
Old February 20th, 2006, 04:07 AM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
did mine, that occurs generally due to wear in the rear layshaft bearing which allows it to twist. Reverse gear acts on the layshaft. I repaired mine with a new layshaft, layshaft bearings and reverse gear. The only problem I had was removing the 5th gear extension case from the main box. You need a special puller from landrover to remove the oil seal ring from the gearbox output shaft so you can open the gearbox casing. All in all it cost me about 150 pounds sterling
Old February 20th, 2006, 03:33 PM
mikeslandrover
Mike Hammond
That's rather encouraging, the puller is the only special tool you need?
Did you buy it, hire it or fabricate it?
I was thinking about getting a rebuild kit from Legs.
I've rebuilt a couple of transfer boxes but never been inside a main gearbox.
Mike Hammond
Old February 20th, 2006, 04:23 PM
No special puller needed. A simple set of gear pullers, a deep 32mm socket (i think look it up) and some bearing pullers and you can do the whole box.
Old February 20th, 2006, 05:59 PM
mikeslandrover
Mike Hammond
Things are looking up.
Mike Hammond
Old February 20th, 2006, 07:22 PM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
removing the oil seal ring was really the only major problem I had, Had a mate at the landrover dealer at the time who loaned me theirs. The only other issue I had was getting all the selection forks lined up properly when putting it back together as at the time I didnt have a manual. Took a couple of goes and a phonecall to someone who had a manual, but it was a minor issue really
Old May 29th, 2006, 05:04 PM
mikeslandrover
Mike Hammond
Just 3 months after destroying the gearbox I've finally got round to dropping the transmission today.
I'm going for a recon box from Ashcroft, there's a fair bit of wear on the output shaft and the input shaft is leaking again. All in all after 100,000 miles I don't think the old box owes me anything
I'm getting distressingly good at gearbox removal as this is the 4th time in about a year and a half that the transmossion has been out
Mike Hammond
gearbox help !! mud_man Defender Technical Discussions 12 November 28th, 2005 12:29 PM
'97 D90 external gearbox cooler pipes. kiphartzell Defender Technical Discussions 0 March 29th, 2005 11:51 AM
beat up broken trashed jump seat dnewman9 Wanted 0 June 27th, 2004 12:38 PM
broken valve cover bolt...help!!!!!!!!! erik d Defender Technical Discussions 2 November 10th, 2003 03:12 PM
