It's muffler time - Defender Source
Old June 13th, 2012, 08:18 AM
LB Defender
Eric Beth
94 Defender 90
It's muffler time
I blew apart the mild steel muffler on my NAS 94 D-90. So it looks like I'm going to have to replace it. The price of the OEM muffler is outrageous so I'm looking for aftermarket.
When I crawled underneath to examine what was going on, besides the big f'ing hole I found, I saw one of the cats had been replaced already by one of the previous owners. I'll guess that more than just the cat was renewed because all of the pipes in and out of the muffler are fine with no signs of rust through or even softness.
I'm thinking of just replacing the muffler and not an entire cat back system. Business sucks and I would rather not spend more than I have to (but getting a quality part is a must). I'm leaning towards a magnaflow and to that end does anyone have a part number for just the muffler?
Also, is there any reason why just replacing the muffler is not a smart move?
Eric
Old June 13th, 2012, 08:21 AM
Last I checked you just go on their site and say what make, model, year you have and it tells you everything.
Old June 13th, 2012, 08:43 AM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
I had the local shop weld a Magnaflow into the Disco.
Got the handy dandy tape measure out and figured out the longest one that would fit...cut the old one off and welded the new one in.
No biggie.
Old June 13th, 2012, 09:43 AM
Naplm00
Matthew
x2 the maganflow SS universal replacements are cheap and easy to get. Come in every in/out size under the sun.
performancepeddler.com has good deals and so does amazon
check magnaflows site for a part number after you measure the pipe diameters and go nuts
Old June 13th, 2012, 11:18 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Does your current setup have bolted connections at the muffler? If so, you will need to either cut these off and use slip connections/clamps or weld in the replacement muffler. I went through the same things you are a little while back and opted for a Flowmaster because they have an "offroad" series muffler that takes a little more abuse because the case is made of almost 1/8" diamond plate. I chose to buy two Walker connectors (41723 & 41726) for about $10 each to weld onto the muffler to re-establish the bolt in connections.
Old June 13th, 2012, 11:24 AM
KKilo23's Avatar
KKilo23
Kenny
Part number is 16711.... check amazon I think I saw it on there for 530 + Shipping.
Old October 12th, 2012, 02:48 PM
dsh12
Daniel Hayes
1994 Defender 90 Soft Top
Muffler Replacement
What bolts did you use to secure the muffler flange to the cats and tailpipe? Were there springs involved or just nuts and bolts?
Dan
Dan
94D90 NAS 3.9 LT77 LT230T Soft Top
There are no guarantees expressed or implied of the accuracy or correctness of the contents of this message, and the Author is not liable for the taking of any action in reliance upon the contents of this message. As always, do your own research. To the extent that opinions are expressed in this message, they are not necessarily the opinions of the Author.
Old October 13th, 2012, 07:50 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Dan
I just used some M10 bolts with washers and nuts...no springs
Replace the whole damn exhaust or just muffler and tail? hutch Defender Technical Discussions 12 February 3rd, 2009 07:41 PM
Catalytic Converters and Muffler OCD90 Defender Technical Discussions 1 January 19th, 2005 01:24 PM
What a time to be without the D JBurt Misc. Chit-Chat 3 December 11th, 2004 06:07 PM
Anyone want a free muffler? Buckon37s Misc. Chit-Chat 9 August 8th, 2004 11:16 PM
Time Mike Hippert Support & Suggestions 3 October 1st, 2003 09:30 PM
