It's deja vu all over again - my 2nd 3.9L dropped sleeve - Page 2 - Defender Source
Old May 2nd, 2009, 10:45 AM
globallandrovers's Avatar
globallandrovers
Julian Kotting
1999 P38 DT, 1997 LHD 110 CSW
Location: Hertford UK, Wilmington, NC, Austin, TX and OH
Originally Posted by jaherring
From Turner Engineering UK at $3000 for a short block before shipping the exchange rate is not good enough... I could find a 300TDi for not much more than that....
So could I use my 3.9L intake and EFI system, do I need to use my heads as well, or ?
You mentioned I'd need to swap in a 4.2L chip into my ECU - that's it?
$3000 for a tdi motor will get you a take out unit, all tdi's here have a minimum of 100,000 miles on them, low mileage units dont exist IMO, Defender 200tdi's are rarer than rocking horse shite. And a rebuilt turn key 200/300 will set you back a minimum of $4000.
Turner make great engines, the quality is second to none. I agree with pendy - go with turner.
Land Rover Defender Specialist. - We ship worldwide.
We are a specialist in TDI re-power conversions, and Crate 'turn key' Land Rover TDI and TD5 engines and Transmissions.
Old May 2nd, 2009, 11:19 AM
a small hijack but relevant. Will a 3.9 vbelt cover work on a 4.2 serpentine block? I am guessing 3.9 ancillaries wont work on a v-belt block?
Old May 2nd, 2009, 11:40 AM
pendy's Avatar
pendy
jim pendleton
89'd90
So you want the cliff notes since I will not write the book?
4.2 serpentine is still and early casting. External oil pump front cover will work, if my memeory serves me correctly. And I believe the cylinder heads have all the relevant holes tapped for the earlier anchillaries.
Why don't you want to keep the serp belt setup?
legend in my own mind
Old May 2nd, 2009, 02:27 PM
I dont have serp. I was thinking about a 4.2 from a 95 to a 91
Old May 2nd, 2009, 03:10 PM
pendy's Avatar
pendy
jim pendleton
89'd90
95 is the only year RRC is serp It is a straight drop in as is for the most part. Into your D90.
The earlier 4.2's are v-belt already.
Do you have a motor located in particular? Maybe best to find one then come ask the questions.
Old May 2nd, 2009, 04:12 PM
I hope Ive got time. I was mostly interested in the ancillaries and what wouldnt work from my vbelt if I did end up with the serp configuration. I need to go through the archives I suppose. I am familiar with years had and how they were configured. I would like to keep it all as simple as possible. the GEMS truck and the cross bolted mains are nice but no harder than I run a truck I dont see the need. I am asking questions so I will get the right engine. I am sure I could hotrod a 3.9 a little they seems to be plentiful.
Old May 3rd, 2009, 01:44 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Some early serp belt engines have a distributor which makes it a drop in for you. But these early engines will not be cross drilled on the mains. 4.2 in 95 RRC LWB or 3.9 in 94 95 Disco.
Hotrod an early 3.9 is a viable option. It really comes down to what is available to you at what cost. And how much you want to spend above that to make it what you want.
If you just want a bit more rebuild what you got with a crower cam and have it balanced. You may not even need to replace the pistons. If you are not running it as hard as the threads' posters truck.
Old May 3rd, 2009, 02:51 AM
Pendy is grumpy tonight.
Old May 3rd, 2009, 12:49 PM
artm
Arthur Maravelis
97 SW
Nobody's mentioned pinning the liners. Isn't this a solution to this problem in these motors? I'd try that on a dirt cheap 3.9 and not worry about being out much.
Old May 3rd, 2009, 01:16 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Dunno, doesn't everyone here get excited enough to JO over their vehicles once in awhile?
What is 'pinning' the liner? I have heard there is an expensive retro-fit liner option which has a 'top hat' lip on it to prevent droppage.. but I've never heard of pinning before.
A V-belt 4.2 sounds like the perfect solution... but also sounds like a rare motor to find.
Old May 3rd, 2009, 02:06 PM
artm
Arthur Maravelis
97 SW
Pinning is nothing more than drilling a bolt through the block and liner and grinding it smooth. Stops any liner shift. I've seen it done on diesels as well.
As for the 4.2, I have one in a 93 RR LWB that I'm trying to sell:
http://boston.craigslist.org/gbs/cto/1152362867.html
You're in CA so it probably isn't cost effective, assuming you're interested.
Old May 3rd, 2009, 02:11 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
You wouldn't separate the motor and ship it, would you?
Old May 4th, 2009, 11:32 AM
artm
Arthur Maravelis
97 SW
No. I don't want to be stuck with having to part out this truck and have it sit in the yard longer than necessary.
If anyone wants to help out by purchasing it from me and doing a deal with you for what you want that's fine.
3.9L Engine For Sale harrellee For Sale - Parts 0 January 19th, 2006 09:36 PM
Steering Wheel Sleeve mpodgorski Defender Technical Discussions 5 December 12th, 2005 10:46 AM
!995 3.9L V8 for Sale Barnett Childress For Sale - Parts 1 September 7th, 2005 04:04 PM
1995 D90 NAS Frame, 3.9L V8 & Radiator for sale Barnett Childress For Sale - Parts 10 June 22nd, 2005 07:38 PM
Why not remove the inner bushing sleeve? ezzzzzzz Defender Technical Discussions 0 June 10th, 2004 07:00 PM
