Its cold outside! - Defender Source
Old November 22nd, 2008, 10:53 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Its cold outside!
Its cold! And the 300 Tdi takes FOREVER to warm up, what can I do? Block heater? Block up the grille like dumptrucks do?
Old November 22nd, 2008, 11:22 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
I put an remote starter in my truck 2 yrs ago. Not sure if it will run long enough to warm up a Tdi. It runs for 15 min then shuts off. You can restart it if need be. I start mine from my shower in the morning.
About $50 from autozone.
Old November 22nd, 2008, 11:31 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
The TDI does not warm up well when Idling... Def. get a Rad Muff from RN. It helps. The temp was 26 this morning..
Legend in My Own Mind.
Old November 22nd, 2008, 12:05 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
True enough. It was 17 when I started my 200Tdi the other morning. It never warmed up until I started driving it. Time to start plugging in the block heater and perhaps put that muff on it.
Chance
Old November 22nd, 2008, 01:18 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
75 F here, no warm up issue
- Charles Eames
Old November 22nd, 2008, 01:24 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
It doesn't take that long. From when I leave my house it takes 2 miles of 45-50 mph driving to get good heat (prior to that you just suck it up), and that is in Maine where the real cold is. I run a muff in the dead of winter and it helps, but not really for initial heat, but it does help to keep the heat up once it comes.
You'd need to get a secondary heater (block heater, or other) if you want a faster cabin warm ups.
My truck will loose heat when it idles. It can be toasty and then if there is a trail traffic jam or something it cools off to virtually no heat again. They need load to build heat.
A little snow this morning and about 25 degrees. Windy and they say the wind chill is -1 (F).
Brrrrr
Email:
Old November 22nd, 2008, 01:38 PM
DaveG
David
97' Disco-I 300TDI
I have a heater that's installed in the coolant hose that heats the fluid. Makes a huge difference on cold days. On days that It's been sitting I'll just plug it in for 20-30 mins before I'm ready to go and it does a nice job of warming things up.
Old November 22nd, 2008, 05:20 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Radiator muff or block heater.
Remote starters, which start your car and just let it idle are worse for an engine than starting and driving off, no matter how cold it is. Plus, engines warm up faster under load than at idle. Not to mention that if you lose oil pressure, or have a fire, you don't know it until it's too late.
On a Tdi the risk is even greater. If it decided that day to blow a turbo seal, not as likely at idle, but possible, the engine would probably self destruct. A runaway diesel isn't pretty.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 22nd, 2008, 05:21 PM
I have an Espar. Its a thousand bucks, but I like it.
Old November 22nd, 2008, 05:43 PM
Cold in NC ????
Joel I know you are used to 30ft tall camp fires but ....
Old November 22nd, 2008, 05:57 PM
On the subject, where is the best place to put a block heater on a TDI exactly? I have one I installed on the frame, with splice ins on one of the heater lines, and then into the line that runs down the right side of the radiator, but I'm not sure if it's optimal. I want to hear about setups that are proven, and the points that they are tied into the coolant system.
Old November 22nd, 2008, 06:29 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I have been in GA all week and it was really cold, I had no idea it could be that cold in GA
Glad I am back here in Colorado where I do not need to wear a coat today
Old November 22nd, 2008, 06:41 PM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
I put a RN muff on my defender and it seems to have made a difference. It's snowing here in Des Moines today.
Old November 22nd, 2008, 07:19 PM
xrover's Avatar
xrover
Len Cater
1997 D90
You should order the proper block heater that goes in the engine block. I live in Toronto and it did a great, in fact barely had to warm up the glow plugs. I bought a extension cord that has a built in switch that comes on below x degrees (I don't recall what it was). I picked it up at a place that sell truck stuff. But once on the road, if it's 0 degrees f the air ingress will overpower the highest heat coming from the 300tdi. I ended up going with a webasto cabin heater, installed under the seat box (110 rhd). I had the outlet in the second row and provided excellent heat up through the back. Espar or Webasto is the way to go.
'97 D90 NAS
'06 Argo Avenger
Old November 22nd, 2008, 07:28 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Brrrrr
I found out about it loosing heat when Idling on the trails last winter wheeling at RC. We were nice and toasty until we got onto the trails and then my feet froze the rest of the day. I guess there is no cure for that other then a secondary heater.
Have any of you guys with Muffs made holes in the intercooler area? I never did but wondered about it.
Old November 22nd, 2008, 08:06 PM
artm
Arthur Maravelis
97 SW
Noone's mentioned...recirculating the interior air by replumbing the intake. A chance to also plug up that useless fender vent which just collects snow and ice in the winter.
Old November 22nd, 2008, 09:35 PM
pendy's Avatar
pendy
jim pendleton
89'd90
The 2.8l has a different freeze plug size. I have not been able to match it up here in the states yet.
legend in my own mind
Old November 22nd, 2008, 09:42 PM
I have the RN muff and cut out the intercooler hole. I think it helps with power if you've been on the highway a while, but I made my hole a bit too big, and it lets a lot of cold air spill over to the radiator. I'm thinkin gof getting another, cutting out a smaller hole that is clear of the radiator (I think about 2" wide would be plenty, and then having a velcro rolldown flap available, so i can use the muff when fording to protect the radiator. that would be the setup right there.
Also, I had seriously been pondering replacing my clutch fan for electric Kenlowes to optimize fording capability with a cutoff switch, and I'm wondering if switching to the kenlowe and controlling the relay for them with a thermostat switch in the block might be an effective way to stay warm as well? Anybody using electric fans with TDI's? I'll bet the lack of a fan running might warm that engine up on low rev. Question is, will a Kenlowe keep my TDI's cool enough in desert/jungle conditions?
Old November 23rd, 2008, 12:32 AM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
A webasto has been mentioned, and it seems like that is the best option if you can find one (may have to look in Canada). It seems the best because it doesn't need a cord or electricity to heat up, it just burns a small amount of diesel fuel like a mini-furnace and uses that heat to warm both the block as well as the cabin. The ones for VW's have timers so that if you always leave the house around 7:30am, you can set the timer to always come on at 7:15am and then by the time you get in the truck, it's toasty warm and ready to start.
Here's a link to start the search: http://www.webastoshowroom.com/blueheat/
Old November 23rd, 2008, 05:30 AM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Webasto Blueheat ...
That is what I installed in mine and I also took the remote and timer so you can start it remotely or with the daily timer. The Webasto has an internal pump that circulates the coolant and also has a an option to turn the cabin fan on if you want. If you take the later option keep in mind you will need a dual battery setup or else you might not have the necessary battery power to turn your truck on after.
Pat
Kirk Lazarus, Tropic Thunder
Cold Weather Starter Problems boshea Defender Technical Discussions 9 October 25th, 2005 04:35 PM
a/c not cold jblieb Defender Technical Discussions 1 September 15th, 2005 10:34 PM
Excessive Cold Weather Exhaust boshea Defender Technical Discussions 3 January 9th, 2005 02:44 PM
1st really cold weather questions mspell Defender Technical Discussions 6 December 20th, 2004 08:40 PM
? for you cold weather people javelinadave Defender Technical Discussions 8 November 24th, 2004 12:34 PM
