Its cold outside! - Page 2 - Defender Source
Old November 23rd, 2008, 10:25 AM
xrover's Avatar
xrover
Len Cater
1997 D90
I picked up my diesel webasto cabin heater used for $400. Did not come with the fancy timers, but worked great since it is instant heat. Very little battery draw as it only needed it for the glowplug and small blower fan. Easy to pipe into the fuel line. The only issue is where to put it. Like I said earlier, I had an '83 110 RHD, so under the drivers seat was the tool box area, which fit the webasto perfectly. The output was about a 1 1/2" diam tub which i mounted to the lower floor bulkhead behind the driver seat. It also had an air diverter to postion the flow from there.
Check the used market, and of course buyer beware when buying used.
'97 D90 NAS
'06 Argo Avenger
Old November 23rd, 2008, 10:56 AM
A Webasto or Espar coolant heater can be had on eBay for around $600 to $700. It is the cat's pajamas. Wonderful. On mine, I added a $15 wireless relay to start it. Even better.
Next would be a block heater. Temro part number 3100087 for the 200 or 300TDI. Much cheaper and work great as long as you can plug it in.
Old November 23rd, 2008, 04:05 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Originally Posted by Maryland 110
Cold in NC ????
Joel I know you are used to 30ft tall camp fires but ....
Yeah you are right in the aspect that it usually dosent get cold enough here to warrant block heaters and $600 Webasto heaters, but this past week or so has been abnormally cold here for this time of year. Its usually not like this until January, then by the end of Feb its nice and warm. I can deal with it, just worried about the engine/trans always running so cool. Another diesel trait Ill have to get used to I suppose.
Cold Weather Starter Problems boshea Defender Technical Discussions 9 October 25th, 2005 04:35 PM
a/c not cold jblieb Defender Technical Discussions 1 September 15th, 2005 10:34 PM
Excessive Cold Weather Exhaust boshea Defender Technical Discussions 3 January 9th, 2005 02:44 PM
1st really cold weather questions mspell Defender Technical Discussions 6 December 20th, 2004 08:40 PM
? for you cold weather people javelinadave Defender Technical Discussions 8 November 24th, 2004 12:34 PM
