It is stalling bit it ain't the stepper!! - Defender Source
Old February 6th, 2013, 11:23 PM
RickM
Rick Mabus
95 D-90 ST
Ok gents. I got a new one. My truck recently went through the entire stepper stalling coil spark plug issue. All that got taken care of. It has a fuel pump that is about 2 years old and fuel relays. Anyway recently it has started randomly having a massive kick when under power and then the next time the clutch goes in it dies. I can downshift and it will still die at the stop light. Anyway, I go to restart it and all is fine. The behaviour is always consistant but the timing of the behaviour is extremely inconsistant. I am woried the computer is about to let loose. I have not put a computer on it. Any thoughts? Thanks in advance.
Old February 7th, 2013, 08:37 AM
It's not the ECU. Check your ground straps.
Old February 7th, 2013, 09:35 AM
Grover's Avatar
Grover
Check your ignition module.
Old February 7th, 2013, 11:12 AM
RickM
Rick Mabus
95 D-90 ST
I know what the ignition module is but the ground straps are a new one to me. Where might one find those?
Thanks.
Old February 8th, 2013, 01:21 PM
landrovermanuk's Avatar
landrovermanuk
John Lindsay
1986 Land Rover 90, 3.9Efi
I had this, replacing the ignition amplifier cured it. On mine it's fitted next to the coil, on some models it's on the side of the dizzy..... Hope this helps...
Land Rover 90, 3.9Efi Auto, Soft Top, NAS spec, Tangiers Orange.
Land Rover owners like it rough and dirty...
Old February 8th, 2013, 04:15 PM
RickM
Rick Mabus
95 D-90 ST
While I was at it, last night I was driving my kid to get a banana split, and down the street from me a dude had a two of a kind rover parked out front. As we all know they used a rover in Tomb Raider. Apparently the movie company used two defenders to promote the movie. They then sold them. Apparently some guy named velvet bought one in Missouri, and then put it up for sale on ebay. A neighbor of mine bought it, and had it parked out back yesterday. if it had not been dark I would have snapped some pics. Great looking rig. Had the TD in it. It apparently was built on an 83 chassis. I will see if I can't get some pics of it.
Old February 8th, 2013, 04:25 PM
Sounds like someone bought snake oil
Old February 8th, 2013, 04:58 PM
Grover's Avatar
Grover
Thanks.
Ground cables are on the back of the ds head, coil mounting bolt and the ds transmission housing.
Check all wires from the ign mod, coil and dist.
I chased a similar problem and the ign mod was the culprit.
Good luck...
Cheers...
Old February 8th, 2013, 06:10 PM
Currently chasing a similar issue myself:
http://www.defendersource.com/forum/...ad.php?t=42780
Got sidetracked when I broke some things on my fuel tank, but got all new fittings on and almost ready to go back in. Just figured I'd paint my fuel tank cradle mounts while I had it out, so as soon as the paint is dry it'll be going back in for testing. I know you replaced your fuel pump, but there's a list of other things that could be the culprit on my thread as well.
Old February 8th, 2013, 09:37 PM
RickM
Rick Mabus
95 D-90 ST
I will dig into this tomorrow in terms of cracking into the straps. Thanks for the input guys.
Code 48 Stepper motor devinchi Defender Technical Discussions 8 September 8th, 2005 05:43 PM
stalling bjenk Defender Technical Discussions 5 May 7th, 2005 12:56 AM
Installing a Napa Stepper Motor p# 2-1738 Heath Defender Technical Discussions 0 January 13th, 2005 10:04 AM
Stepper motor same on RR? waveridin1959 Defender Technical Discussions 15 December 16th, 2004 10:52 AM
dirty stepper??? ttegt Defender Technical Discussions 1 March 31st, 2004 10:37 PM
