It died on me today... - Defender Source
Old July 6th, 2012, 12:27 AM
hunterjah's Avatar
hunterjah
Jesse Hardin
Past: '97 D90 LE #135
So I was driving down the road today (about 98 degrees in Dallas) and my truck died on me as I approached a stoplight. I had just finished a 90 mile roadtrip. For 80 of the 90 miles, I left the AC off and windows down as I have been feeling like my truck is running hot. About 10 miles to home, I cut the AC on. What was strange is I also had my radio on and I noticed a severe lack of sound coming from the stereo when I turned up the volume. Then the volume cut back on, but the truck died when I came to the stoplight. I turned the AC off, cranked her back over and started right away. Drove the rest of the way home without AC.
Any thoughts? My first thought is perhaps a bad alternator, it should be pretty simple to measure the power output on the unit right? I don't have any major modifications. There was an Alpine head unit (no amp) and an alarm system (that I hate and want to remove) when I bought the truck. I have a winch and two Hella front lights, but none of that was on today. Only the AC and radio were on.
I guess I'm partly concerned about the truck running hot. I haven't heard the fan kick on again like it did a month or so ago after a full day of running in about 95 degrees. I also don't think these two are related issues, but you guys are so much more knowledgeable than I about these things. Any thoughts are greatly appreciated.
Current Stable:
2016 BMW M3 (Mineral Grey)
2013 Ford Raptor (Tuxedo Black)
Previous Rovers:
1997 LR D90 LE - #135
1997 LR D90 ST - #1185 (BRG)
2000 LR Discovery SII (Oxford Blue)
2008 LR LR3 HSE (Alaska White)
2012 LR LR4 Lux (Fuji White)
Old July 6th, 2012, 06:21 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Any flickering battery warning light?
Sent from my iPhone using Forum Runner
Old July 6th, 2012, 07:38 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I would look at the A/C compressor and fans. Both take power from the engine and the alternator. After the truck cools down, next day etc, does the truck run with the A/c on?
Land Rover 110
Old July 6th, 2012, 09:16 AM
hunterjah's Avatar
hunterjah
Jesse Hardin
No flickering battery light that I saw, I did see the oil light and seatbelt light come on once the truck died. Related to starting the next day, the AC stays off if I start it. It's never started the next day with the AC on.
Could be related, but does anyone hear a "clicking" noise when your AC is on. It sounds like a consistent click or tick and definitely stops when you turn the AC off.
Current Stable:
Previous Rovers:
Old July 6th, 2012, 09:57 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
I noticed that when I was having my alternator issuies the AC would vary in speeds and the componets drawing current would act out of ordinary...is it possible your alternator is doing a slow burn? just a thought. it may be something along those lines if it's all random and recent!?! Also in the weeks up to the alternator problem I did notice an increase hum over the speakers when I had the radio on. It was strange but in the end the alternator was the fault but it didnt just fail it was a four or five week process.
Old July 6th, 2012, 10:12 AM
hunterjah's Avatar
hunterjah
Jesse Hardin
Funny you mention the radio quality, I've noticed more static on the sports station I listened to. I think I'm going to point my finger at the alternator first and see if I can't find a way to measure the output to diagnose if it's dying.
How did you diagnose the alternator dying?
Current Stable:
Previous Rovers:
Old July 6th, 2012, 10:18 AM
texrover's Avatar
texrover
Jason
I'm not expert but removing the overheat concerns, sounds like an alternator. That's where I'd start.
I never had electrical issues (alternator etc) with my 90, but, I did have a '69 Bronco that did exactly what you are describing (but I didn't have a radio). It would stall at every intersection and die. I'd have to roll start the car and make all kinds of crazy right turns at red lights to keep it rolling and pop the clutch to start.
In the end I replaced the alternator on the road (as well as re-did the points/coil) to finally get it reliable.
On the overheat, you're probably at the age that you need a new radiator. But before you go that far replace the $13 thermostat. But a rad flush if it's not too far gone would be second (or replace)
2003 RR L322
1971 Series IIA
1983 110 SW (Incoming)
1994 D90 ST (PO)
Old July 6th, 2012, 11:21 AM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Is your tac still working? It runs off of the alternator. So when that starts going wonky or stops that is a good sign it is an alternator problem.
Sounds like a lose of a power to me as well.
Old July 6th, 2012, 11:46 AM
Bill Larson
Bill Larson
yes my tach was acting a little weird but nothing severe, unlike the first time i replaced the alternator. this is the second alternator in a year and a half. the first one just stopped putting out. One the second one the regulator was going and putting out to much current and overcharging which resulted in other issuies. This second go round the tach wasnt acting too funny...nothing abby-normal for a defender. the battery light flickered twice that I noticed...I think I like everyone else here gets into their defender like they get into a suit...it is part of you and you can almost sense when there is a problem.
My issuies were almost undetectable, but you knew something was going to happen. The shop I took it into detected the problem, so I had a more defined expectation of what was to come, but I just had to wait as it was not consistant.
Old July 6th, 2012, 12:14 PM
BCN's Avatar
BCN
BRIAN
94/D90/#1337/AA YELLOW
speedo
Will odd fluctuations in the speedo indicate the same problem?
Old July 6th, 2012, 12:43 PM
hunterjah's Avatar
hunterjah
Jesse Hardin
I am seeing that too, but I chalked that up to other issues. Not huge fluctuations, just slight bouncing in the needle. I figured that was just the age of the speedo. I've not noticed anything abnormal with the tach. The truck runs great with the AC off.
I've also noticed that the truck will run real rough at idle after I've used the AC and turned the truck off. So, I turn the AC on, drive, then park. Once I get back in to startup, the engine runs rough almost like it wants to die. But, I gave it a little gas the times this has happened and nothing persists.
I think I'll play with it this weekend a bit. I'm thinking the radiator and alternator are two separate issues at this point.
Current Stable:
Previous Rovers:
Old July 6th, 2012, 12:50 PM
Bill Larson
Bill Larson
I didnt experiance that, just the tach as its connected to the alternator.
------ Follow up post added July 6th, 2012 11:51 AM ------
yes the problems do seem to come in waves...!
Old July 6th, 2012, 02:00 PM
BCN's Avatar
BCN
BRIAN
I've had the same issue with my newly purchased 94 ST (114K - I'm owner #3) but chalked it up to a cooked harnass in the engine bay. I patched with new wiring and it seemed to cure the problem until she quit on me last weekend. Fired right up too but I am concerned. I have noticed the odd bounce of the speedo (rpm works fine) and slight "weakness" at idle particularly when caught in the heavy stop and go. My stereo will very occassionally loose power and reboot even when not on. A/C is disconnected due to bad compressor.
I spoke to Owner#1 and he stated that the alt is 2-3 years new so I had crossed it off my list. I thought perhaps the fuel pump was weak (it's the original) or loose wiring but it looks like the alt is back on top... I'll see if I get lucky and track it down this weekend and let you know what I found...
Old July 6th, 2012, 02:21 PM
hunterjah's Avatar
hunterjah
Jesse Hardin
Please do, I'm going to read more this weekend about how to trouble shoot a faulty alternator. Then beyond that, I may need to take her into my mechanic.
Current Stable:
Previous Rovers:
Old July 6th, 2012, 02:58 PM
texrover's Avatar
texrover
Jason
BTW, have you taken it by to have Alan look at it (North Texas Rover)?
2003 RR L322
1971 Series IIA
1994 D90 ST (PO)
Old July 6th, 2012, 03:39 PM
hunterjah's Avatar
hunterjah
Jesse Hardin
Not yet, Alan has done all the work on it so far though. He does good work! I'm in the tinkering mood this weekend, but I won't end up doing anything big unless I feel like I can pinpoint something obvious.
Current Stable:
Previous Rovers:
Old July 6th, 2012, 03:54 PM
Sudden death is often a fuel pump fuse, relay or motor.
Old July 6th, 2012, 04:13 PM
triple9music's Avatar
triple9music
Chad Davis
1984 Defender 90
you can put a screwdriver up to the alternator and listen for some grinding. It'll still work, but like Bill said it's just a matter of time. We had a weird grinding coming off a 94 NAS D90 and that's how we pinpointed the grinding. Replacing that alternator this weekend.
Old July 6th, 2012, 04:30 PM
hunterjah's Avatar
hunterjah
Jesse Hardin
A motor? Say what?
Current Stable:
Previous Rovers:
Old July 6th, 2012, 04:32 PM
Bill Larson
Bill Larson
I experianced the same noise on the first alternator...there were also small chunks of a ceramic material that I assume came loose from inside the alternator that were laying on the engine in the V hollow.
Saw this little beast on Ebay today WCURoverD90 Misc. Chit-Chat 7 March 23rd, 2005 02:09 PM
Got muddy today Millsy Misc. Chit-Chat 4 February 27th, 2005 05:12 PM
She died! rustydefender Misc. Chit-Chat 5 January 5th, 2005 08:24 PM
My drive today Joe P Misc. Chit-Chat 16 January 12th, 2004 11:49 PM
d90 screwed me today! HELP!!!! vesparover Defender Technical Discussions 5 December 3rd, 2003 10:49 AM
