Is this the wrong tensioner? (300tdi) - Defender Source
Old August 16th, 2010, 12:39 AM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Assembling the front of the motor this weekend had me scratching my head - the A/C tensioner is in the generally correct location according to the manual (see first attached image) but when routing the belt it rubs on the nut that holds the tensioner pulley (see other photos).
The manual also mentions 3 tensioner retaining bolts - this one only has one. Maybe this is the wrong part?
Does someone have a photo of their 300 tdi A/C tensioner pulley setup?
ID:	30167   Click image for larger version
ID:	30169   Click image for larger version
Old August 16th, 2010, 10:47 AM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
Well, I'm no expert on every possible configuration of the 300tdi, but your tensioner looks nothing like mine. Mine's exactly like the diagram. I have mine where I can get a good picture at the moment. I'll try to post up a picture tonight if no one else chimes in first.
------ Follow up post added August 16th, 2010 10:16 AM ------
Wait a second...did you assemble that tensioner? It looks like you might have the tensioner pulley mounted to the wrong hole in the plate. It should be in the offset hole and the other three should be concentric.
8-track, gun rack, spittoon, gimbal mounted beer buoy, blah, blah, blah, blah......
Old August 16th, 2010, 12:48 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Doesn't look like mine either, i'll try to snap a pic today.
- Charles Eames
Old August 16th, 2010, 01:47 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
That indeed is the wrong type of tensioner.
Here is one in place:
as mentioned above, it bolts on using the 3 bolts that hold on the FIP pulley cover, and you loosen these 3 bolts to enable the tensioner "arm" to pivot around (using a 1/2" drive lever) and tension the belt.
Old August 17th, 2010, 01:00 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
OK, thanks for the photo - that confirms I simply do not have the right tensioner. The tensioner I have was clearly 'rigged' by someone.
I don't have that 3-hole plate w/ the tensioner pulley attached to it - I have 'something else'.
Anyone know where I can get one of those slightly closer than the UK? RDS does not have it, I just asked George.
300tdi, tdi
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
300Tdi wings/ radiator finisher (defender) Lyman Wanted 2 March 8th, 2006 05:51 AM
Is a 300tdi really the cats tits? EndlessEarth4WD Misc. Chit-Chat 21 November 8th, 2005 04:49 PM
1995 Discovery 300TDI, Trail Ready.... Joe B For Sale - Vehicles 1 June 23rd, 2004 06:26 PM
