Is this lifter noise? 95 NAS V8 D90 - Defender Source
Old July 17th, 2014, 03:27 PM
ymc226
Lawrence
1995 D90 SW NAS
I hear a "machine gun" tapping noise coming from the driver side of the engine compartment in the last few days whenever I press on the gas semi aggressively, especially in 1st gear. The noise becomes very subtle as I shift to 3rd or 4th but I think I can still hear it. If I downshift, though the revs increase, the noise doesn't occur.
It doesn't come on for the first few mintutes with a cold engine but rather when the engine warms up. I've had the car less than 1000 miles (26,000 miles on new engine block) and the PO always used either Mobil 1 0W40 or 10W40 Synthetic High Mileage. If it is lifter noise, would adding something like STP ZDDP treatment help? Just don't want any wear/tear after all of the prior owners took such great care.
Old July 17th, 2014, 05:11 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Originally Posted by ymc226 View Post
I hear a "machine gun" tapping noise coming from the driver side of the engine compartment in the last few days whenever I press on the gas semi aggressively, especially in 1st gear. The noise becomes very subtle as I shift to 3rd or 4th but I think I can still hear it. If I downshift, though the revs increase, the noise doesn't occur. It doesn't come on for the first few mintutes with a cold engine but rather when the engine warms up. I've had the car less than 1000 miles (26,000 miles on new engine block) and the PO always used either Mobil 1 0W40 or 10W40 Synthetic High Mileage. If it is lifter noise, would adding something like STP ZDDP treatment help? Just don't want any wear/tear after all of the prior owners took such great care.
I've had belts that are loose make some pretty distinct noises, sometimes they hit against guards or other bits in the engine to produce a tapping noise
I'd check to make sure it's the engine first
Old July 17th, 2014, 06:16 PM
Could it be an exhaust leak from the manifold gaskets? They are usually louder when cold in my experience, but are the loudest under load.
90, 95, d90, nas, v8
Lifter noise after oil change Campbell Defender Technical Discussions 4 November 21st, 2009 11:14 PM
Swapping out a bad lifter? turbodave Defender Technical Discussions 6 December 8th, 2008 04:01 PM
Lifter / engine tapping... oil pressure issues.. revtor Defender Technical Discussions 10 July 12th, 2007 11:04 PM
Tappet/lifter tolerances after rebiulding heads Neil McCauley Defender Technical Discussions 3 January 18th, 2007 08:28 AM
Lifter Noise JimVT Defender Technical Discussions 5 February 28th, 2005 12:46 PM
