Is this bad? - Defender Source
Old March 12th, 2015, 05:20 PM
Landyman1's Avatar
Landyman1
Landyman
1983 land rover 110 county
A this bad. I have no idea what I'm looking at here. Recently my land rover has had a bit of trouble starting Click image for larger version
ID:	115934 Click image for larger version
ID:	115935 it's a 3.5l v8
Old March 12th, 2015, 05:21 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Be more specific in your description of your starting problem.
Does it start? Is it just slow?
1970 SIIA 88, Sold
Old March 12th, 2015, 05:26 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
Theres a burnt wire that looks like its part of the starting system which is what I think he's referring to, however, the burn marks look like its external but someone else chime in cus I could be wrong.
If you're having trouble starting be sure to not keep the ignition in the starting position for too long as the wires will heat up and catch fire, don't ask how I know.
Old March 12th, 2015, 05:29 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I would say it has not been properly maintained, yes.
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
i don't know what that pipe that is rusted and burnt out behind the wires is but I wouldn't start the car until I figured out what that is and what it was supposed to do. That's why the wires look burnt.
Old March 12th, 2015, 05:30 PM
His problems look worse than that.....
Old March 12th, 2015, 05:41 PM
V8 Carb? It would help people if you told them a little about the truck beyond a couple of close up photos of the engine.
I think that is a disconnected air injection system and disconnected PCV system.
Old March 12th, 2015, 05:43 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
That rusted out pipe is the air injection system as used on SD1 Rovers, didn't think Land Rover fitted that system.
You must have one hell of a exhaust leak, does it sound like a freaking train going down the road?
You can do the job properly and blank off the inlet holes on the head or change the heads. What a cobbled mess you gots there. What else is hiding under the bonnet?
And get some decent plug wires as yours are burnt.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old March 12th, 2015, 05:59 PM
Is that the fuel rail?
Old March 12th, 2015, 06:00 PM
Just saw the second pic. Doesn't appear to be fuel rail.
Old March 12th, 2015, 06:03 PM
roverman2010
1985 LR 90 200Tdi
No fuel rail, Carbs
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old March 12th, 2015, 06:09 PM
Roverman2010 already gave the correct answer above.
Old March 12th, 2015, 06:10 PM
Landyman1's Avatar
Landyman1
Landyman
Oh and the wires are fine. It was just a bit of exhaust heat. But nothing was actually burnt. Just dirt.
Old March 12th, 2015, 06:12 PM
Landyman1's Avatar
Landyman1
Landyman
This a 1983 land rover 110 county with a 3.5l v8. Twin zenith Stromberg carbs. 114 hp. One of the earliest 110s (built in the first month of production).
Old March 12th, 2015, 06:19 PM
3 more HP than a 200/300Tdi and half the MPH. Amazing!
Old March 12th, 2015, 06:24 PM
Landyman1's Avatar
Landyman1
Landyman
Do you know any sites or books I can look to for repairs? Also, I can get to around 90mph. Like the space shuttle, which is nicknamed "the flying brick" the defender is "the driving brick".
Old March 12th, 2015, 06:40 PM
Download he factory workshop manual. Available all over the net.
If it can do 90 it is running fine.
Old March 12th, 2015, 06:52 PM
transientmechanic's Avatar
transientmechanic
1972 SIII
What about the exhaust leak? Those rusted out pipes go directly to the exhaust ports in the heads...
Old March 12th, 2015, 06:57 PM
Already answered.
Originally Posted by roverman2010 View Post
You must have one hell of a exhaust leak, does it sound like a freaking train going down the road? You can do the job properly and blank the inlet holes on the head or change the heads.
Old March 17th, 2015, 01:31 AM
Landyman1's Avatar
Landyman1
Landyman
Does anyone know any part numbers for the system? Turns out it's the original air injection system as per the 1983 3.5l v8.
Gas Storage--Gone Bad? When will gas go bad in a Jerry Can? pcscharfe Misc. Chit-Chat 7 August 29th, 2007 05:42 PM
Need Help For Bad Handling...(I mean BAD!) Cube II Defender Technical Discussions 18 July 7th, 2006 09:07 AM
Bad luck! TwisteD90 Misc. Chit-Chat 2 March 12th, 2004 01:14 PM
Help! Bad noise out of right rear!! P1CR Defender Technical Discussions 14 March 2nd, 2004 09:29 AM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
