Is this bad? - Page 2 - Defender Source
Old March 18th, 2015, 02:16 PM
mcoleman762's Avatar
mcoleman762
Mike Coleman
94 D90 ST/95 D90 SW/83 110
Yep, same system on my truck. I've attached the part numbers. Buying replacements will be expensive. Might be better to properly blank off the inlet ports. But you appear to have all sorts of uh...interesting...things going on with the air injection and PCV systems. As others have said, you have a bit of a mess going on there.
Anyone who has one of these old 110's and still has the original engine and equipment fitted really needs the parts manual.
http://www.amazon.com/Rover-Parts-Ca...+parts+catalog
And here's the workshop manual for the older trucks:
http://www.amazon.com/Rover-Defend-O...orkshop+manual
I'm sure there are versions available for download on the net, but I prefer actual books.
Hope this helps!
Old March 18th, 2015, 02:35 PM
Just blank it off. Why would you want it working?
Old March 18th, 2015, 03:44 PM
Miller's Avatar
Miller
Jon Miller
'85 ROW 110 SW
I had the same air injection pipes on my '85 110. I removed them and blanked the ports on the exhaust manifold using some proper sized set screws from McMaster Carr. Sealed them up well and haven't had any issues since. The previous owner thankfully also ditched the twin carbs and installed an Edelbrock manifold and carb.
ATW!
- Jon
Old March 19th, 2015, 08:12 AM
Landyman1's Avatar
Landyman1
Landyman
1983 land rover 110 county
Originally Posted by mcoleman762 View Post
Yep, same system on my truck. I've attached the part numbers. Buying replacements will be expensive. Might be better to properly blank off the inlet ports. But you appear to have all sorts of uh...interesting...things going on with the air injection and PCV systems. As others have said, you have a bit of a mess going on there. Anyone who has one of these old 110's and still has the original engine and equipment fitted really needs the parts manual. http://www.amazon.com/Rover-Parts-Ca...+parts+catalog And here's the workshop manual for the older trucks: http://www.amazon.com/Rover-Defend-O...orkshop+manual I'm sure there are versions available for download on the net, but I prefer actual books.
Hope this helps! Mike
Thanks! I really appreciate you and others taking the time to help me. Defender owners are truly the kindest of the car owners. Maybe even nicer than Canadians...
Old March 19th, 2015, 10:17 AM
Some states have inspectors do a quick look under the hood to make sure all originally fitted emissions equipment is intact. I use short hex head bolts to block off these ports.
Gas Storage--Gone Bad? When will gas go bad in a Jerry Can? pcscharfe Misc. Chit-Chat 7 August 29th, 2007 05:42 PM
Need Help For Bad Handling...(I mean BAD!) Cube II Defender Technical Discussions 18 July 7th, 2006 09:07 AM
Bad luck! TwisteD90 Misc. Chit-Chat 2 March 12th, 2004 01:14 PM
Help! Bad noise out of right rear!! P1CR Defender Technical Discussions 14 March 2nd, 2004 09:29 AM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
