Is this an edc motor?! - Defender Source
Old June 29th, 2012, 02:06 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Can anyone tell me if this an edc motor? The block code is 18L
Will this require a computer?
What do you have to do to make it not need one?
Can you just hook a throttle cable up to it?
Old June 29th, 2012, 04:33 PM
It is not EDC
You will need a throttle cable.
Old June 29th, 2012, 04:37 PM
Broncoduecer
peter
D90
I got wondering when I saw the wires on the pump. Is that a tps sensor or a interlock or something?
That's what was confusing me because it had a throttle arm...but then wires too.
Thanks for the info!
Old June 29th, 2012, 04:56 PM
One wire is to control the fuel cutoff solenoid.
Old June 29th, 2012, 05:30 PM
Broncoduecer
peter
D90
Yea I can see where that one is. There is a 3 wire something on the throttle
Old June 30th, 2012, 12:54 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
The 3 wire black thing on top is for the EGR system (Exhaust Gas Recycling) so that the ECU knows how far the throtle pedal has been pressed. just unplug it. can be removed totally too.
If you have an EDC motor, then you can change the FIP to a non-EDC version... job done.
motor
help with a/c motor Campbell Defender Technical Discussions 3 April 12th, 2005 12:25 PM
'89 rangie needs motor Abrooks For Sale - Vehicles 18 October 18th, 2004 01:19 PM
A/C blower motor Campbell Defender Technical Discussions 3 September 9th, 2004 11:01 AM
Replacement Motor and Trans for 110 gearco Defender Technical Discussions 39 July 2nd, 2004 02:16 AM
heater motor lubricant ??? artm Defender Technical Discussions 1 October 18th, 2003 04:42 PM
