Is this a TD5 ecu? - Defender Source
Old February 27th, 2011, 07:58 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Is this a TD5 ecu?
I just got the truck home and found this under the right side seat. I assume its an ECU, it also has the fly by wire gas (?) pedal.
Obligatory dog pic
I meant for this to be posted in the Defender Tech Discussion section
ID:	36201   Click image for larger version
Old February 27th, 2011, 08:34 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Yep that is what it looks like. The under seat fuse box is the black box behind it. You should have some more fuses on the inside firewall. What engine are you going to install?
Land Rover 110
Old February 27th, 2011, 10:09 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
200tdi
Old February 28th, 2011, 10:12 AM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Yes, TD5 ECU. Same coolant tank for TD5 as well. I'd be interested in the pedal as a spare.
Nice truck and dogs. Mark
Old February 28th, 2011, 03:23 PM
Capt Milks's Avatar
Capt Milks
Are you going to get a new wiring harness? You could probably get a late 300 Tdi main harness that would work pretty well. If the dash is complete you could even use the electronic dash. I have some part numbers if you need it.
Land Rover 110
Old February 28th, 2011, 08:10 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I was hoping to use the harness thats in there, the TD5. My guess is that there would be a lot of extra wires.
My other option is to use the one from the 1983 110.
Old February 28th, 2011, 08:49 PM
Capt Milks's Avatar
Capt Milks
You can download a 2002 Td5 wiring diagram off the UK web. It should point you in the correct direction on the wiring and colors. Some of the forums also have a blog on how to convert the Td5 Gauge wiring to work with a 300 Tdi sending units, temperature gauge. You need to get a new sending unit, green, and then play with a couple of the wires. I purchased the gauge wiring harness that was for the last of the 300 Tdi's running the Td5 electronic gauges.
Land Rover 110
ecu, td5
Speed Sensor and ECU Issues DJ Menasco Defender Technical Discussions 14 February 16th, 2006 08:45 PM
D90 TD5 ECU Chip upgrade? Should I or not? adibitar Defender Technical Discussions 11 September 1st, 2005 01:22 AM
Where did you put your ECU jcasteel Defender Technical Discussions 6 January 12th, 2005 11:31 AM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
Maybe FS: 1999 Defender 110 Td5 mlepisto For Sale - Vehicles 3 March 18th, 2004 02:17 PM
