is this a stock spring setup? - Defender Source
Old September 28th, 2011, 11:46 AM
spartan's Avatar
spartan
Fred
83 D110
Im looking to replace my springs but before I do I need to know if my current setup is OEM. The shocks are Bilsteins. Im not planning to do any real off road so I would like to keep the ride closer to stock. The truck is a SW without a winch.
I attached a photo of the ride height at the rocker panel. The tires are LT285/75 R16.
Can anyone tell me if I have the original springs? I have 103,000 miles so I would like to replace the springs when I clean up/paint my suspension next week.
ID:	42332   Click image for larger version
Old September 28th, 2011, 12:06 PM
Yep....just pulled mine off...same ones (but mine were in much worse shape). The white/white *should* be NRC8044:
http://rovers.red90.ca/springinfo.html
But now that I look can't tell if there's a "second" white on there. So you may want to check the above to see if you can find the color code if it's only single white.
NAS 110 stock spring measurement Devin W Defender Technical Discussions 1 November 17th, 2006 10:43 PM
305/70/16 on stock setup? howellm70 Defender Technical Discussions 7 January 11th, 2006 06:43 PM
Spring Isolators wicks Defender Technical Discussions 16 January 28th, 2004 02:37 PM
Stock 90 Parts for Sale Joe B For Sale - Parts 2 October 15th, 2003 11:57 AM
