Is there good metal or plastic fan replacement for the plastic D90 radiator? - Defender Source
Old December 12th, 2011, 05:57 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Question Is there good metal or plastic fan replacement for the plastic D90 radiator?
British Pacific says they are out of stock on the plastic allmakes radiator fan. I guess I could order one from Rovers North but before I do that, whats a good replacement I can get locally at Autozone/pepboys etc? Metal or plastic, I'm curious if you guys used any aftermarket fan that will bolt right to the viscous fan clutch. Mine has a chip on it and its seen better days. Any help is appreciated.
Robert Deniro
Old December 12th, 2011, 06:07 PM
Range rover fan and clutch there is a thread about it
Old December 12th, 2011, 06:17 PM
Neil McCauley
Neil McCauley
lemme find it. Thanks!
------ Follow up post added December 12th, 2011 04:20 PM ------
So basically, we have to use a RRC fan & clutch and modifty with washers so it dosen't hit the fan shroud? Sounds fun. sigh...
Robert Deniro
Old December 12th, 2011, 07:38 PM
Neil, you unscrew your two screws on your shrowd, there are washers on top and below there usually. Pull them out, and slide them all UNDER the shrowd, and screw them back in. Pretty damn simple.
Old December 12th, 2011, 07:48 PM
Neil McCauley
Neil McCauley
So we don't have to change the viscous clutch? We can use the one we got if its still good?
Robert Deniro
Old December 12th, 2011, 08:05 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
nope, you would need a RRC clutch with the new RRC fan. The clutch can be found relatively cheap as a hayden product. but if you just need a new Defender fan and your truck runs fine I would try to source a used one.
Old December 12th, 2011, 08:08 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Daniel,
Doesn't Josh have your RRC fan still!??
Old December 12th, 2011, 08:14 PM
Neil McCauley
Neil McCauley
I'm going to hit up autozone tonight and see what I can find there. Thanks!
Robert Deniro
Old December 12th, 2011, 08:30 PM
ini88's Avatar
ini88
Daniel Marcello
Originally Posted by tjfslaughter View Post
Daniel,
yup, that dirty SOB still has it Lucky for him I have like 2 spares.
90, ac, d90, fan, radiator
D90 radiator surround for sale or trade cdb For Sale - Parts 0 October 29th, 2009 11:53 PM
Fan Belts Replacement kleedee Defender Technical Discussions 6 August 15th, 2005 09:15 PM
WTB - d90 - Good to Great Deal. uzj100 Wanted 1 July 15th, 2005 12:54 PM
Trade my 1997 D90 for disco + cash dave_lucas For Sale - Vehicles 21 March 31st, 2004 12:51 PM
