Is my transmission always low on fluid? - Defender Source
Old January 12th, 2007, 08:48 PM
cpk
Corey K-nig
1993 NAS Defender 110
So I'm underneath putting in new fluid in the transmission and I started thinking. Do I have to have the wheels rolling to activate the pump in the tranny while I'm filling it up? I filled it up until it started to dribble out the hole. Once I start to drive it will the pump push a large volume of fluid up to the cooler leaving the level of fluid in the transmission lower? Because there are breather hoses, I think this allows all the fluid to drain out of the cooler into the case when the Rover is at rest? Does this make sense or does the cooler remain filled with fluid all the time?
Old January 12th, 2007, 09:22 PM
Nah man. If its the R-380 its good when it starts running down your sleeve. Fill it up and check when you change your oil. And if its and R380 (manual w/ reverse to the lower right) it doesnt have a cooler or pump. You can over fill by jack the passenger side up but I dont think its worth it. What kinda fluid did you put back in?
Old January 13th, 2007, 10:29 AM
cpk
Corey K-nig
It is a rebuilt R380 I got from Rob Dassler. I've been putting Royal Purple Synchromax in it, suggested by Rob. It had the piece on the side that the cooler lines go into so I think it does have a pump though. Thanks for the info.
Old January 13th, 2007, 12:11 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Corey,
Fill it, drive it to warm it up & fill the lines, recheck & top up as necessary. If the lines were empty you may have to add a few ounces.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
transmission
transmission fluid leaking TravelerBT Misc. Chit-Chat 4 December 6th, 2008 09:02 PM
ZF fluid level goes up and down 48vphantom Defender Technical Discussions 4 March 20th, 2005 01:42 PM
94 discovery automatice transmission capacity cgalpin Defender Technical Discussions 4 August 26th, 2004 10:57 AM
