Is my new sway bar front or rear? - Defender Source
Old February 10th, 2012, 12:11 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Dumb ?
but is this a front or a rear sway-bar?
Old February 10th, 2012, 12:15 PM
Oliver Whiting
Oliver Whiting
84 110, 94 NAS90,Bunch of EX-mods
That diameter it's gotta be the front.
Old February 10th, 2012, 02:01 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Ok, so which helps the handling of the truck more? front or back?
I'm gonna put a 1997 NAS under my 1985, and I figured i'd add some sway bars, mine has none.
Old February 10th, 2012, 02:35 PM
Rear probably more than front. NAS 110s had rear bars but not front one.
Ron
Old February 10th, 2012, 04:32 PM
Ron
Understanding that a rear bar increases oversteer and front understeer.
Old February 10th, 2012, 04:45 PM
How can it do both at once?
Old February 10th, 2012, 07:19 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
So is the sway bar in the pic front or rear?
Old February 10th, 2012, 07:53 PM
LOL... I did not write that very clearly...
Adding a rear sway bar (or putting in a bigger one) increase tendency to oversteer or reduces understeer.
Adding a front sway bar (or putting in a bigger one) increase tendency to understeer or reduces oversteer.
Clear like mud?
Old February 10th, 2012, 08:01 PM
Oliver Whiting
Oliver Whiting
I would go with a front sway bar be for the rear.
Old February 10th, 2012, 08:54 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
The picture looks like a front bar. All that a sway bar does is transfer the load from one side to the other. In an AWD car/truck it isn't quite as important as a FWD/RWD car/truck. The softer the spring and shock rates you have the more you will appreciate sway bars on the road. Off road you will want to disconnect them. I put both front and rear on the 110 and didn't notice much of a difference.
Land Rover 110
Old February 10th, 2012, 09:00 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Old February 11th, 2012, 10:54 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Definately a front bar shown there.
Old February 11th, 2012, 12:38 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Another item that helps is those adjustable/inflatable air bags that fit inside the coils of the rear springs. They're usually sold as a help for a sagging rear end for trailer towing. Since they're inflatable, you can adjust them to suit your fancy.
Old February 11th, 2012, 03:01 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Clear like mud?
OME springs, Bilsteins, 255/85 KM2. I reinstalled the front bar only. More stable at highway speeds and windy roads. It understeers more but safer than with no bars Easy test for this. Find a constant radius off ramp. Increase speed and if it requires more steering input, it is understeering (which is safer than oversteering....).
------ Follow up post added February 11th, 2012 03:02 PM ------
Originally Posted by tomaco1
Dumb ?
What brand are those disconnects?
Front Sway Bar Spacers and Disconnects CDeWan Wanted 6 July 14th, 2017 01:23 AM
Rear anti sway bar available Chaucer For Sale - Parts 3 December 29th, 2009 07:21 PM
bigger sway bar for rear CDeWan Wanted 0 May 15th, 2009 07:14 PM
Barnett Childress chrisvonc Defender Owners 0 February 29th, 2004 12:47 PM
Locker - Front or Rear bd90 Defender Technical Discussions 6 January 14th, 2004 09:22 PM
