Is my framed tweaked? - Defender Source
Old October 22nd, 2003, 01:22 PM
kit
kit steven
97 d-90
i'm rebuilding my d-90 after if was rolled (not a huge accident but enough to warrant a good look at the integrity and straightness of the frame).
I have measured the distance from a few different points on the car, and have noticed that the two sides don't match up perfectly (we're talking a difference of 1/4"- 1/3" between the two sides when I measure from the rear frame member to the body support outrigger on eac side of the vehicle).
I can't tell if its just the body support outrigger that's slightly out(not a problem) or if it is the whole frame(hopefully not).
Does anyone know if this small difference in measurement will cause a big problem when it's all back together? will it not drive right?
Let me know if I'm overreacting.
thanks
Old October 22nd, 2003, 02:05 PM
easy just buy a new galvanized frame
Old October 22nd, 2003, 02:31 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
A soft rollover is VERY unlikely to have bent the frame. These things a re pretty beefy. If the frame was not directly impacted in some way, you are fine.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 22nd, 2003, 02:42 PM
kit
kit steven
97 d-90
but...
a soft rolloever, yes.
something else i forgot to mention was that it was very difficult to remove the crossmember (maybe bent out of shape). It's like it had been altered in some way making me think that it was a sign that other problems exist.
any ideas?
Old October 22nd, 2003, 02:44 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Which crossmember?
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 22nd, 2003, 02:46 PM
kit
kit steven
97 d-90
the gearbox crossmember that is removable.
Old October 22nd, 2003, 02:49 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
It is not uncommon for that to be very difficult to drop. I had to soak overnight in grease to tear mine out. If you are very worried, take $50 and drive the truck down to a good body shop and have them hook up the lasers. I really doubt the frame is tweaked.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 22nd, 2003, 02:54 PM
kit
kit steven
97 d-90
i'm beginning to think the same.
an ounce of prevention...i guess.
thanks
Old October 22nd, 2003, 04:07 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
The tolerances were pretty lose on the frame when it was made. I'd have the axle alignment checked front to rear. Any ripples on the chassis frame are cause for alarm.
The chassis rails may need to be spread with a hydraulic ram to get the gearbox X member to drop out. A damn good beating with a really big hammer is the other way of doing it but that method isn't in the repair manual
Mike Hammond
Old October 22nd, 2003, 06:19 PM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
Before you start worrying too much, make sure the tubular outriggers are square (run perpindicular to) with the chassis. There may be no cause for alarm if one of the outriggers is moved. And, if one is moved, your measurements don't have any value until you straighten it back up. Believe it or not, these chassis are made of THIN metal, and are easy to tweak. The LR manual says that most measurements should be within a tolerance of 4-7mm, some as small as 2, others greater than 7. Hell, when they glavanize chassiss, they probably warp that much. Good luck.
Old October 22nd, 2003, 07:00 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Exactly... these things are not straight from the factory. When I installed the crossmember in my brand new galv. frame I had to spread it with a hydralic ram about 1/4" to get it in place. It was a real bitch....
Old October 22nd, 2003, 07:01 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I used a high lift to spread mine!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 22nd, 2003, 07:34 PM
kit
kit steven
97 d-90
allright, I guess there's not much reason for me to be alarmed.
thanks everyone.
(i wonder if they'll ever make a straight frame?)
Old October 22nd, 2003, 08:03 PM
probally when they make one that doesnt leak
Old October 22nd, 2003, 09:17 PM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
I used a hi-lift and 2 2x4's to spread my chassis to get the crossmember in. Look, if your chassis is tweaked, and your body panels don't fit correctly, don't worry about it; it is probably still better than most defenders that leave the production line .
I've Been Framed! chris snell Misc. Chit-Chat 2 December 2nd, 2005 10:42 PM
