Is LPG...LPG? - Defender Source
Old June 8th, 2011, 06:05 PM
atpick's Avatar
atpick
Andy
1990 110
Is LPG...LPG?
This might be a stupid question, but I guess I have to ask it. Is the LPG I filled my Defender up on in Europe, the same as the Propane and I can get from the redneck RV park off the highway here in Clovis? I want to go fill it up this week but I want to make sure that all propane is the same, meaning, when I fill it up and switch from normal petrol, my Landy isn't going to blow up. I guess the other issue might be the connector port for filling the tank up, not sure if the British connector is the same as the one here in the States.....thoughts?
-Andy-
Old June 8th, 2011, 06:15 PM
exmod110's Avatar
exmod110
Don Lang
http://en.wikipedia.org/wiki/Liquefied_petroleum_gas
Think it is.
85 exmod 110 rhd 300tdi
Old June 8th, 2011, 07:40 PM
TS888's Avatar
TS888
Tony Sims
1984 110
I'd be surprised if the connector is the same. All the bottles in the UK use different regulators and connectors than US, I had to swap over to run my gas bbq.
Tony
1984 110 "Smokey" (sold)
Old June 8th, 2011, 07:59 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
x2 about the connector, but amazon, etc should have an adapter.
Can you post a pic?
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old June 8th, 2011, 08:12 PM
jetmech's Avatar
jetmech
Dave McHenry
1984 Landrover 90 CSW
I mioght have an adapter if you need one. I'll look in the shed.
Old June 8th, 2011, 08:28 PM
atpick's Avatar
atpick
Andy
1990 110
Can you post a pic?
Here's a couple of pictures. I could use some type of adapter if one is needed.
Old June 8th, 2011, 08:31 PM
atpick's Avatar
atpick
Andy
1990 110
Can you post a pic?
Ok, now with pictures I hope
Name:	2011-06-08 18.18.59.jpg
ID:	39494   Click image for larger version
Name:	2011-06-08 18.19.11.jpg
Old June 8th, 2011, 09:21 PM
Stormer's Avatar
Stormer
JP
2008 RRSC
I think it's terribly dangerous and you should swap your Rover for a mildly used jetboat immediately! Otherwise, think you can fill up with CNG with the right adapter.
------ Follow up post added June 8th, 2011 07:37 PM ------
Note: CNG is typically at much higher pressure than LPG so check the safety limits of your tank!
Old June 8th, 2011, 10:01 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I'm not sure LPG system will work with CNG. Those system work with drastically different pressures.
- Charles Eames
Old June 8th, 2011, 10:18 PM
Rugbier's Avatar
Rugbier
Gustavo
Actually your local RedNeck Gas provider will have an adapter or change the filler for you
NO SIGNATURE
Old June 8th, 2011, 10:23 PM
atpick's Avatar
atpick
Andy
1990 110
only one way to find out
------ Follow up post added June 8th, 2011 08:24 PM ------
Good point, rednecks are resourceful....and I should know being from North Georgia
------ Follow up post added June 8th, 2011 08:28 PM ------
JP! Are you trying to get me to blow up the rover so I get insurance money and buy your boat?
Old June 8th, 2011, 11:30 PM
Stormer's Avatar
Stormer
JP
2008 RRSC
Absolutely not! If you haven't blown yourself up by now, highly unlikely to happen. Although you may not want to chance it when you could be cruising in your new boat.
Boat is actually going in water in bay side of OBX in 2 weeks.
Old June 9th, 2011, 09:04 AM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Andy I ran my 90v8 on lpg, propane and butane with no problems for about 5years & as long as the vaporiser is drained often you will have no problems.
be aware that industrial propane is often contaminated with various oils and tars.
I used to fill my tank up from large propane bottles using a hand pump, working in a steel works with a father and a son that are welders i found propane was never a problem to obtain for free.
I bought a kit of adaptors from Ebay to use in europe where each country countries had different pump fittings.
In my experiance LPG in the UK was almost as dirty as propane whereas LPG in europe was very clean meaning the vaporiser and pipes did not get clogged with oily crap.
regards
gren
Lpg? atpick Defender Technical Discussions 12 November 6th, 2010 08:31 AM
LPG Natural Gas Conversion Kit bstraw For Sale - Parts 0 December 16th, 2006 04:58 PM
LPG addition to Diesel motors little black duck Defender Technical Discussions 5 November 24th, 2006 11:52 PM
