Is it possible to swap out the motor mounts with the engine in situ? - Defender Source
Old September 15th, 2010, 07:34 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
I'm trying to figure out if its possible or if anyones done this. I just changed the transmission mounts and those were fairly easy, it would seem that i would lift the engine up considerably to get enough clearance to get the mounts out. What say ye?
neil
Robert Deniro
Old September 15th, 2010, 07:51 PM
bjf's Avatar
bjf
barry f
94 ST #395
You need Horsey to fly out, get under the truck and leg press the engine up while you change the mounts. I think he has some strong quads.
Old September 15th, 2010, 08:00 PM
Neil McCauley
Neil McCauley
Yea Josh has huge calves this is a known fact. I bet his calves are so strong that he's dented the footwells in his bulkhead.
Robert Deniro
Old September 15th, 2010, 08:28 PM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
Not to mention some serious cankles!
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old September 15th, 2010, 08:52 PM
Neil McCauley
Neil McCauley
I invision Josh's D90 has a braking system similiar to the ones used in the flintstones era
Robert Deniro
Old September 15th, 2010, 09:00 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
How long are the studs on the motor mounts ?
- Charles Eames
Old September 15th, 2010, 09:12 PM
Neil McCauley
Neil McCauley
Like an inch long on both end, they were pretty long though, I trying to figure out if I have to take the steel motor mounts off as well or can i do it with just taking the rubber mounts off. Josh has calves the size of tree trunks.
Robert Deniro
Old September 15th, 2010, 10:47 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
I don't know about the D90, but on my D2 I am able to change the motor mounts without removing the engine... put a jack under it and lift it up, or put a hoist above it... there is enough play to get them removed.
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old September 16th, 2010, 01:32 AM
bjf's Avatar
bjf
barry f
94 ST #395
I heard when Horsey jumps he is actually pushing the earth away from him while he stays in place
Old September 16th, 2010, 01:38 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Yes it can be done. Pass side one is pretty easy, drivers side sucks because of access. Undo and remove all the nuts. Drivers side one nearest the engine will have you inventing new and interesting cuss words. Lift the engine until you can wiggle them out. Wiggle in the new ones and replace the nuts.
Old September 16th, 2010, 07:49 AM
That may be the first thing you've said that I've actually laughed at.
Man I thought this was going to be a really boring technical thread. Then I saw multiple posts by bjf and Jon and knew it must have taken a dark turn away from the technical.
------ Follow up post added September 16th, 2010 07:51 AM ------
This is fact.
engine, motor, mount
Swap 200 Tdi woth a BMW or Mercedes engine lakis Defender Technical Discussions 20 December 13th, 2015 11:37 AM
Is an engine swap a do-it-yourself job? bd90 Defender Technical Discussions 5 September 5th, 2010 05:19 PM
Thinkin' about an engine swap! rustydefender Misc. Chit-Chat 11 June 17th, 2005 09:30 AM
