Is it OK to throw in the towel? - Defender Source
Old January 14th, 2012, 02:26 PM
Well, I'm all into this transfer case schmidt with the Loob. I have the replacement one sitting on the driveway but the one in the vehicle is being a real bee-yoch. I'm at the point where I'm ready to call the transmission shop and have them do the darn thing. I'm on my back working with no room, the truck is on stands, it's cold, I can't make any progress, I have better things I could be doing...
I guess I am ready to call this one and let the someone else do it. Does that make me a bad owner?
Old January 14th, 2012, 02:57 PM
Nothing's hanging it up except my gumption. Not a good day.
Old January 14th, 2012, 08:50 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Bad owner? No way! You're maintaining it whether you do it yourself or not. Life's too short to worry about it and the sooner you get that truck on the road the better off you are.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old January 14th, 2012, 11:29 PM
greenmountainrover's Avatar
greenmountainrover
Derek Chace
84 Lightweight FFR
Your only a bad owner when you seriously start considering using the destruction and denial from enemy section of your Rovers owner manual...
If I had C4, or a descent rifle my Lighweight would never have left the woods.
Green Mountain Rovers your Defender/Series sales and importation specialist.
802-655-4874
Old January 15th, 2012, 11:18 AM
I did mine in winter too but I borrowed someone's garage and transmission jack. We had to slightly pry it to get it past the lip of the body work aft of the trans.
We also had to separate the exhaust center can from the y-pipe and allow the entire drivetrain to tip down at the back until the clutch fan hit the shroud.
Hope that helps. A blanket to lay on and thermal long johns help too. All that said, I am putting off some maintenance too. It just too cold to get me motivated.
Yes it is tempting to send the vehicle to someone for help. But if experience can be use as any kind of guide, I know that most likely I will be unhappy with the result.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old January 15th, 2012, 01:00 PM
I'm not sure why but this all sounds familiar
I wish I could offer more motivation, but the cold does the same to me. Maybe check the forecast and take some time off on a warmer day?
Originally Posted by pendy
I'm here for the D's
Old January 17th, 2012, 12:39 PM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
A couple Miller High Life's always make my auto work go better.
Old January 17th, 2012, 01:26 PM
I ended up punting the ball. Worked on other RRC to get it ready for the street. Got the wipers working but they park in the middle of the windscreen.
Old January 17th, 2012, 06:22 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
Look on the bright side. At least they park.
John Karlsson
Hope Valley, RI
Throw out bearing staple, are we suppost to glue it in? Neil McCauley Defender Technical Discussions 4 August 31st, 2010 09:21 PM
short throw shifter, anybody find a good one? FlaD90 Defender Technical Discussions 11 January 7th, 2010 06:15 AM
throw away rear view mirror Overlander Wanted 2 October 15th, 2007 05:13 PM
Just replaced clutch; throw out bearing rattle Noah Defender Technical Discussions 7 August 29th, 2006 04:23 PM
Tires, Tires, Tires Joe P Misc. Chit-Chat 28 August 9th, 2005 09:58 PM
