Is an engine swap a do-it-yourself job? - Defender Source
Old September 3rd, 2010, 11:30 PM
bd90
94 Arles Blue #1644
I found a 4.2 long block to replace the 3.9 and was wondering if doing the swap myself (provided I get my hands on an engine hoist) was something I would later regret or should I just let the mechanics do it. I thought I would ask the folks here before I let the mechanic talk me out of doing it. Are there any things in particular that I should watch out for? Maybe some snags that someone here has encountered that I should know about? Do the alternator, compressor, etc have to be attached differently and are the wiring harness connections the same on both engines. I mean are they truly identical engines except for greater CID. Any advice would be appreciated.
Old September 4th, 2010, 08:06 AM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
It is nice to have an extra pair of hands when moving heavy things like a motor. Even though you have a hoist - you will still need a little muscle to get things lined up and to help with the occasional top / bottom bolts.
Firemanshort
1980 Stage One 109
Sterling, VA
Old September 4th, 2010, 07:04 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
It can be done, but like David says, another pair of hands really helps. I always end up doing swaps on my own though.
Semper Fi!
Old September 4th, 2010, 11:21 PM
berti1554
Robert Klima
84/110
Alterantor, compressor, wiring harness is all the same. Put on a new clutch. And yes, it's really a DIY job assuming you have two helping hands
Old September 5th, 2010, 07:41 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Yep mostly done them myself, Dunsfold Land Rovers did my first tdi swap though - I had nowhere to work on it at the time.
Mike Hammond
Old September 5th, 2010, 05:19 PM
Not a huge deal. Make sure to get a big hoist and/or drop the front end down or remove it.
Also, an impact gun with some long extensions (18-24in cobbled together) with a u-joint fitting on the end makes the transmission bolts 10x easier.
engine
Swap 200 Tdi woth a BMW or Mercedes engine lakis Defender Technical Discussions 20 December 13th, 2015 11:37 AM
Engine Swap? TravelerBT Wanted 31 November 22nd, 2008 12:05 PM
Thinkin' about an engine swap! rustydefender Misc. Chit-Chat 11 June 17th, 2005 09:30 AM
