Is a TD5 swap possible on a older 110?? - Defender Source
Old January 25th, 2017, 12:46 PM
Fender
Reinier
1991 D110
Anyone done a TD5 swap on a older 110? Fed up with my 300 tdi the wiring aspect doesn't scare me
Old January 25th, 2017, 12:51 PM
Sure. Probably makes more sense to use one of the upcoming Cummins ISF 2.8s instead unless you get all of the parts really cheap. Same level of work and probably similar cost, but you get all new modern parts.
Being in Canada, you might as well just import a factory TD5 truck and sell your old one to the US. A lot less work and probably a lot cheaper.
Old January 25th, 2017, 01:02 PM
The_Vermonster's Avatar
The_Vermonster
Gordon
1984 110 CSW
If that 300Tdi is in the '91 Fender has listed then it won't make it into the US. It's not an original engine. Otherwise I would agree. a complete TD5 truck would be much nice than a transplant.
Old January 25th, 2017, 08:44 PM
Fender
Reinier
1991 D110
Yup it's a1991 a real td5 would make more sense just not the 40 k pricetag lol and having to do the import again
Old January 25th, 2017, 08:54 PM
40k? You should be able to easily buy a truck and import for well under 20k.
Old January 25th, 2017, 09:23 PM
Fender
Reinier
1991 D110
I've seen a few LHD for around 9000 euro that needed body work but nothing solid yet. Also high miles ..the search continues! Anyone want a diesel automatic csw 110??
Old January 25th, 2017, 10:00 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
For €,9,000 - €10,000 all you are only going to find is high mileage, a long list of mechanical repairs, and/or a fine example of corrosion at work.
Old January 26th, 2017, 04:57 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
I've built a few Td5 rovers now (my current 110, my old 90, and a friends tomcat)
For a defender, you just get all the parts from various sources and plug it all togther. you need everything though, nothing is the same as Tdi
bulkhead loom, engine looms, front fender LH & RH wiring looms, rear chassis loom (which runs the electric tank pump). under seat fusebox. all plug and play though.
10AS alarm unit and engine ECU (go for an NNN500020 as they're defender spec and reprogrammable)
fuel tank (plastic, different to the Tdi as the pump sits inside the tank... may be the same as NAS, I don't know)
fuel pipes and filter
seat box is pretty similar, just a bracket under the RH seat for the ECU and fusebox to sit on.
engine & gearbox obviously. you could change the bellhousing on your current 300Tdi to a Td5 spec one.
chassis mounts (weld on). you can use the 300Tdi gearbox crossmember (Td5's gearbox brackets were welded to the chassis), but if you use the Tdi one, you need to cut and route the exhaust around it, or just "notch" a piece of the crossmember out so the standard exhaust can go through..this is what I have done on my 110.
radiator and intercooler (which are the same as the later puma 2.4 and I think, 2.2 engines... intercooler certainly is)
if you want the factory alarm to work (the 10AS unit, which you will need anyway regardless of if you actually activate the alarm portion of it) then a couple of plippers, coil for the ign switch, and an internal movememt sensor, plus the alarm sounder (two types available, plain "horn" or BBUS, battery backed up sounder)
front & rear propshafts. front has larger wider angle UJ's too.
all the parts are pretty easily available in the UK or euroland. prices not too silly either.
Someone on the defender2 forum has a compete Td5 "kit" for sale...well, engine & box and ECU:
DEFENDER2.NET - View topic - [For Sale] Complete TD5 Drivetrain
Old January 26th, 2017, 06:46 AM
Fender
Reinier
1991 D110
Ok thanx I am considering both options now l,my trucks in good shape low mileage and over maintained everything's been done to it.
What I really didn't want to do was import another and then have to take it all apart to replace15 years of use again to get it reliable as a daily driver but the maths will dictate which way I go
Old January 26th, 2017, 07:06 AM
Chris B
72 + D1 drivetrain =?
Originally Posted by CDN38 View Post
For €,9,000 - €10,000 all you are only going to find is high mileage, a long list of mechanical repairs, and/or a fine example of patina at work.
Fixed that for you
Old January 26th, 2017, 01:28 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Originally Posted by Rocky View Post
Fixed that for you
Once again... burned by political correctness.
Old January 26th, 2017, 01:33 PM
Fender
Reinier
1991 D110
Thanx lol! Found a few more td5's I upped the price looks like I'd be about 25 grand cad to get a decent 240 000 km 110 stationwagon with a mot guess I lucked out when I found mine most trucks forsale on Dutch kijiji are over 200 000km
Old January 26th, 2017, 05:04 PM
Buy this, 2000 Land Rover Defender 110 Pickup Truck | used cars & trucks | Fredericton | Kijiji
Shuffle some body parts and sell the old one.
Old January 26th, 2017, 06:00 PM
Fender
Reinier
1991 D110
Nice need a four door version of that 130? Good price
Old January 26th, 2017, 10:06 PM
exmod110's Avatar
exmod110
Don Lang
I dont think you will get the cummins cheaply.
85 exmod 110 rhd 300tdi
Old January 27th, 2017, 07:16 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
My opinion is that a 300tdi is reliable.. TD5 has head problems.. I don't believe it would worth it doing all the work and pay all invoice. If you really fancy a TD5, buy a newer truck..
Old January 27th, 2017, 07:20 PM
Fender
Reinier
1991 D110
So the td5 is no better than the 300?
What sort of work would A td5 defender would require besides a head gasket prior to daily use?
I would rule out the Cummings conversion
Newest I can go is 15 years old and it has to be LHD for insurance
Red90 I like that truck in nb too bad it's rhd
Old January 27th, 2017, 07:57 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Some prefer the 300 for it's simplicity over the Td5.
The Td5's main issue is the early model 10P engine is prone to head failure, once a new updated head is on, no real issues. Being electronically controlled, they can be tuned for considerably more power and torque.
I'm at 130,000km on mine, original head, no issues, drives great, lots of power, it's a great engine.
The Cummins is cool, but I do wonder what the weight difference is between that and the Td5, and Tdi? If it's a lot of extra weight over the front end, what are the handling characteristics, and implications on suspension. I don't know, but am curious to find out.
Old January 27th, 2017, 10:58 PM
The_Vermonster
Gordon
1984 110 CSW
The Cummins is listed at 503lbs. No solid number on the 300, but most put it in the 450-500lbs range. So I would say it's a minor difference, worst case.
Old January 27th, 2017, 11:03 PM
The cummins is about the same weight and size as a TDI.
110, td5
Swap td5 gearbox for 6 speed Deslehany Truck Build-up's & Restores 0 July 1st, 2016 05:26 AM
Best VALUE adding MOTOR SWAP for older 110 in USA? WestCoastRover Defender Technical Discussions 29 March 29th, 2016 01:23 PM
Td5/R380 Swap Ash For Sale - Parts 2 July 17th, 2015 05:50 PM
Suspension for an older 110 boswalt Defender Technical Discussions 4 November 30th, 2011 10:01 AM
TD5 dash stowage tray fitment in an older 110 jayz Defender Technical Discussions 0 September 26th, 2011 08:12 PM
