Is a Disco I VSS compatible with LT95 4-spd? - Defender Source
Old April 19th, 2011, 04:59 AM
Miller's Avatar
Miller
Jon Miller
'85 ROW 110 SW
I already posted this question in the giant VDO thread, but there hasn't been any response. I'm hoping there is better visibility in this section.
I'd like to updgrade to VDO gauges and I'd prefer to ditch my old speedo cable and go electronic. Is the Disco I VSS (YBE100540G) compatible with an LT95 4-spd gearbox?
I've searched the forum and found a few posts that touch on this without actually confirming if it will work. A google search yielded a few dead-end threads on other forums as well. I greatly appreciate any info you all can provide.
ATW!
- Jon
Old April 20th, 2011, 07:49 AM
LRover's Avatar
LRover
J. Michael McCaig
I'm guessing yes. I changed out my LT95 for a 5spd and a LT230 and I didn't have to change the speedometer cable.
Old April 20th, 2011, 08:32 AM
James Pierce's Avatar
James Pierce
James Pierce Jr.
Someone correct me if I'm wrong here I haven't been under an 85. The speedo cable is typically driven by a gear on the rear output shaft of the transfercase so it shouldn't matter what transmission you have. Your VSS is then driven by the speedo cable. My guess is you would need the short intermediate speedo cable between the LT230 and the VSS you mentioned above.
Old April 20th, 2011, 04:06 PM
The lt95 is the big "one box" trans and t-case in a single housing, not a separate transmission.
Old April 20th, 2011, 06:08 PM
Should be able to pry the speedo cable drive out and slide a VSS in. The VSS are color coded for different final drive ratio's so if your speedo isn't adjustable make sure you get the right one.
Old April 20th, 2011, 06:13 PM
I assume you meant to say the speedo drive gears are colour coded? For the VSS, there is either the Disco 1 or Defender TD5 ones.
Old April 20th, 2011, 06:24 PM
James Pierce
James Pierce Jr.
Wink
Sorry for adding to the confusion. I should know better : )
Old April 20th, 2011, 07:08 PM
Miller's Avatar
Miller
Jon Miller
'85 ROW 110 SW
Thanks!
Thank you all for the input. I'll pull the trigger on the VSS first and see how it fits. If all is ok, I'll proceed with the rest.
ATW!
- Jon
Old April 20th, 2011, 07:42 PM
Yes John- correct as usual.
Old November 29th, 2011, 07:19 PM
grnrvrs's Avatar
grnrvrs
Paul
88
How did it work out?
1970 SIIA 88, Sold
Old November 29th, 2011, 10:41 PM
Miller's Avatar
Miller
Jon Miller
'85 ROW 110 SW
Not yet...
I still haven't gotten around to this yet. I moved from Germany back to the US on a short suspense. I'd still like to upgrade my gauges to VDO and use the VSS, but it's not a priority at the moment. I'm in the rotary-wing aviator training pipeline at the moment, so I have little time to work on the 110.
ATW!
- Jon
Old November 30th, 2011, 06:55 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Get a OEM sending unit the aftermarket ones, (britpart) are crap and do not read correctly.
Land Rover 110
Old September 18th, 2012, 06:10 PM
grnrvrs's Avatar
grnrvrs
Paul
88
I received a green VDO VSS bundled with my wiring loom. Any idea if that is the right one for a Def or Disco?
Edit: Looks like its YBE100530, for an LT230 Def. Still need to confirm that it will work on an LT95.
1970 SIIA 88, Sold
Old November 1st, 2012, 02:07 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Paul,
Any update on this? Looking to switch over to VDOs if possible. Are you redoing the engine temp and Volt meter too?
MUDSUX
Old November 1st, 2012, 02:16 PM
grnrvrs's Avatar
grnrvrs
Paul
88
No updates yet. I've been working on other bits. NTO 2006 300tdi ROW gauges came with my loom. I'll wait until I'm back on the road to worry about switching to other gauges, if at all. Although a pyro is on my to do list.
1970 SIIA 88, Sold
95, disco
D-90 1994 parts and Disco 2 parts JAD For Sale - Parts 10 August 1st, 2006 03:00 PM
Help empty my garage! Ton's of parts.. RedRhinoProducts For Sale - Parts 12 June 1st, 2005 09:24 AM
Garage Sale - 2ea LT-230, Hood.... RedRhinoProducts For Sale - Parts 10 November 22nd, 2004 08:12 AM
97 trans/xfer into 95 Disco boxerhips Defender Technical Discussions 4 June 10th, 2004 01:08 AM
Lt230 & Lt95 tbmcneill Defender Technical Discussions 4 February 21st, 2004 04:23 AM
