Is 85 amps enough? - Defender Source
Old February 10th, 2009, 09:12 PM
johnpiero
John Brancato
none
Is 85 amps enough?
Hey all.
My electrical components seem starved for juice. For example: my headlights are dim to begin with and when I turn my heater-fan to "Hi" the headlights dim even more-so.
I noticed the alternator reads "Magneti Marelli Type A127i-85" which makes me believe it supposed to put out 85 amps.
It seems to be original so i guess it's supposed to be desinged so.
What else could it be?
BTW, i bought the car like this so i don't know the history. It's a '94 D-90
Thanks.
Old February 11th, 2009, 07:36 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
85 amps is plenty for normal operation.
Unless your alt and/or battery are weak/dead, it sounds like a wiring fault. Check, or have them checked. You can do one check yourself. Put a meter on your battery with the engine running to see if you're getting the right terminal voltage.
Then, given you're in NY, I'd start looking for corrosion around your ground points.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 11th, 2009, 08:03 AM
LRover's Avatar
LRover
J. Michael McCaig
Yeah use a voltmeter and check all your battery and ground connections. Your alternator should be putting out about 14 volts. If it drops with the lights and heater on then I would suspect the alternator. Some auto parts stores (Advance Auto Parts) will check your alternator and load test your battery for free. That might be your best bet.
Old February 11th, 2009, 09:40 AM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
The battery is less than 6 months old... I had a yellowtop optima in there, but I needed that to match the dual battery setup on my disco, so I replaced that with a high CCA Kirkland brand... there was no difference before/after in anything with the battery swap.
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old February 11th, 2009, 11:43 AM
Check grounds and put a relay on the headlights.
Old February 12th, 2009, 07:53 PM
johnpiero
John Brancato
none
Why a relay? What does it do?
Old February 12th, 2009, 09:31 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
That way the lights run directly off the battery rather than through the dash switch. It lowers resistance and will reduce the strain on your light switch.
Old February 13th, 2009, 06:38 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Only thing is, the lack of a relay isn't his problem.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
school me on increasing amps on alternator Overlander Defender Technical Discussions 31 December 13th, 2011 01:02 AM
Anybody running 255 85 16 tebby Defender Technical Discussions 5 October 3rd, 2009 10:06 AM
amps drawn while truck is off ini88 Defender Technical Discussions 20 July 9th, 2009 08:29 AM
what size Winch, Brand ect.... Rover- Girl Defender Technical Discussions 46 April 3rd, 2006 10:36 AM
