Is 210* to hot? - Defender Source
Old September 7th, 2008, 03:11 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
Is 210* to hot?
My D90 is running at almost 210* when the ambient temperature gets into the 90's and above. Is that to hot or is it in the normal range? Normally on a 70-80 day it stays around 185-190.
Gary
Old September 7th, 2008, 03:17 PM
madcowdungbeetle
Carter
I'll put money on it your fan clutch is done. My trail rig does the some thing when I drive it around town, and the fan clutch on it is dead.
Old September 7th, 2008, 04:54 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
That is what I thought also so I just put a new one on it and no change. Also installed a new radiator. It runs at those temps either at highway speeds or around town, but only when it is real hot out.
I guess my real question is how hot can you these engines run and not damage them?
Gary
Old September 7th, 2008, 05:04 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Gary, have you changed your temperature sensor yet? If not, have you changed the gauge?
Old September 7th, 2008, 06:02 PM
How hot is too hot? I know the 5.3 in the GMC sierra its temp gauge sits around 210.
Old September 7th, 2008, 07:36 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
Yep, That is how I know what the temp really is vs the stock C-H gauge. Autometer gauge with new sensor to match.
That is my question. Is 210 to hot? Sure I know in a perfect world 190 all the time would be desired, but when it is 105 outside is 210 to hot for the 3.9l?
Gary
Old September 7th, 2008, 07:43 PM
I just had my Thermostat go out on my ST... I just took it out completely. Gary, I would try the same thing and see if anything changes.
Old September 7th, 2008, 10:18 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
Guess that wouldn't hurt. It seems to work as I can watch the radiator water through the fill hole and it is calm until 180 or so then it starts to flow. But it could be not opening all the way I guess.
Gary
Old September 8th, 2008, 08:46 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
Spray out the fins on your radiator. I was having similar problems and sprayed out my radiator (I thought I had done it sufficiently after my last wheeling) and was amazed at the amount of dirt and crap that came out.
As a stop gap, I have found that kicking the AC on at a stop light to turn on the electric fans can keep the temp from climbing if your viscous fan is shot. I replaced mine and now the truck is running at 190 when it is over 90 outside and I don't need to use the AC fans any more.
Old September 8th, 2008, 04:17 PM
210 won't hurt the engine, but it is in the range where you would think something is a miss in the cooling system. When everything is properly working, these things do not get warm on their own.
Ron
PS OTOH the lotus will run up to 205-210 anytime you sit in traffic and that is supposedly "normal." I turn on the heat as soon as I hit 200.
Old September 8th, 2008, 05:21 PM
GYM's Avatar
GYM
Gary
97 SW
Have you noticed an improvement since removing your T-Stat?
I don't know if it is an urban legend or not, but I have always heard you should not remove the thermostat entirely, because the coolant circulates too quickly and does not cool as efficiently.
Gary: I replaced the blocked driver side wing grille with a RHD vented heater intake grille (from George) to help vent some of the hot under hood air out.
Old September 8th, 2008, 08:08 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
The 210 temp happens at freeway speeds along with around town which makes me wonder what is going on. There should be plenty of air at 65mph even if it is 105 to start....
Maybe I will pull my temp sensor and check it for accuracy in some boiling water.
Gary
Old September 8th, 2008, 08:35 PM
SOUTHPAW26
Kelly
1994 D90-1993 NAS 110#280
Have you tried a infrared laser thermometer? they work very well to see if gauge is accurate.
Old September 8th, 2008, 09:25 PM
huck1974's Avatar
huck1974
shane cates
94 d90
240 to 250 before you have to worry about damage. My new vette consistantly runs over 200 in design.
And hay
And I love you too
Old September 8th, 2008, 09:57 PM
mpsteil
Michael Steil
NAS 110#23,97 ST#665
I wonder if all those BB"S my son poured into the radiator just before you bought the truck might have something to do with the 210 temp? Do the boil test Gary or just get another stat since you would have to reinstall the old one anyway. Cheap enough test at least.
Old September 8th, 2008, 10:31 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
How did forget about this! I have one and will check it.
Thanks Shane, that is what I was thinking but just wasn't sure the Rover engines could take 210 all day on the trail.
HaHa Mike, I found those when I had the radiator recored. I thought is was just some factory debris....
Gary
Old September 8th, 2008, 11:47 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Its to hot.
legend in my own mind
F-in hot down here milli Defender Technical Discussions 14 September 21st, 2005 08:21 AM
Hot New Accessory - Perfect! JimC Misc. Chit-Chat 19 July 24th, 2005 10:49 AM
Running Hot??? Burke Defender Technical Discussions 10 March 21st, 2004 02:33 AM
Playing with Rovers, guns and a hot blonde in Africa wicks Misc. Chit-Chat 1 February 21st, 2004 09:31 AM
Superlift ORV Park in Hot Springs, Arkansas Nov. 20-23 Joe B Trips, Trails and Events 5 November 12th, 2003 10:07 AM
