irregular ticking noise 2.5 diesel - Defender Source
Old May 26th, 2015, 05:02 PM
DefenderMd's Avatar
DefenderMd
Ben
87 defender 110 3 door
I have a tick coming from the 2.5 NAD engine. I can't source it. Sounds louder from everywhere in the engine bay. I tried to use a stethoscope and couldn't locate it.
It sounds like the tick you'd get from a cooling exhaust or something, but doesn't seem to be. Goes away when the engine is shut down. I haven't noticed it when cold. Only after being on the highway.
If its sitting idling it randomly ticks. It may do it at speed, but I can't hear it.
I suppose it might be a lifter or rocker? But it doesn't quite sound like what I'd expect that to sound like. I get probably get .5 ticks per second at idle. They are all exactly the same, but irregularly spaced.
Engine is running smooth, "*strong" and smoke free.
* Strong means I can hold 50 almost anywhere and get to 65 if forced on a flat with the 1.6 tcase
Tried it now, cool. Doesnt tick.. so it must be heat related. Still don't THINK its a cool down tick. as it only happens with engine on.
Old May 26th, 2015, 09:14 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Hot spot might be letting go.
Old May 26th, 2015, 09:15 PM
DefenderMd's Avatar
DefenderMd
Ben
EEgh... I hadn't thought of that. I've never laid eyes on a hotspot really.
I could imagine it making that noise.
Now that i'm all scared of it. feel they're cheap enough to just do that. I read you generally have to mill the head afterwards to get them flush.
What holds them in. I saw something called "hot spot pin" advertised. Others say you hit the edge with a punch to peen it in there.
Old May 26th, 2015, 09:36 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
That or a valve sticking in the guide that occasionally provides excess rocker clearance.
RDavisinVA
Old May 26th, 2015, 09:37 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
Take the head to a machine shop with your new hot spots. They can pin them and then plane the head.....been there...done that. They make a mess when they drop into the cylinder..... Don't ask me how I know.....
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old May 26th, 2015, 09:41 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Newman, I told you to give up those crab 2.5 N/A Diesels...
RDavisinVA
Old May 26th, 2015, 09:45 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
Just doing my part to recycle old crap sir.....
Rick
95 P38 "Gus" RIP
03 D2 SE "Fred"
Old May 26th, 2015, 09:47 PM
DefenderMd's Avatar
DefenderMd
Ben
Thing with the NAD is that it cannot break the driveline.
You'd think it would get better mileage. Seems to be an otherwise sturdy lump with just enough power to get down the highway, but quite at home in town.
the hot spots/plugs cant fall into the engine unless they fracture, right? i mean, they sit on the block. i assume people mean that their hot spot falls apart and into the combustion chamber.
Anyway.. Probably worth picking up the hot spots... taking off the head, checking the valves etc.. just as a preventative. If it kills the tick, great. Doesn't look to be that big a deal.. Probably removing the exhaust manifold without breaking a stud is the toughest part.
Old May 26th, 2015, 10:29 PM
DefenderMd's Avatar
DefenderMd
Ben
https://youtu.be/EmS-7FDgbg0
Old May 26th, 2015, 10:42 PM
I doubt it is anything like a hot spot or anything serious. You are basically wasting your time asking on the internet. This is one of those things that must be found in person. I have a similar sound on my lightweight and it has been poke and prodded by a lot of knowledgeable people and we still don't know.
Old May 26th, 2015, 11:08 PM
DefenderMd's Avatar
DefenderMd
Ben
you're not wrong. But some ideas to poke at.
I knew guys in the LS2 fora that could "name that noise" in one note. in the samba, that crew can name anything about anything from any model. not really the rover world usually. brits tend to bodger. never know though.
I'm on a forum for another engineering subject where most of the time I can solve your issue before you even know how far it goes. Its not quite as complicated as an engine and all its noises though. Actually, it could be argued it is. the one thing I'm good at.
Old May 26th, 2015, 11:13 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Don't worry about any ticking, rattling or clacking noise, just drive it till it blows up then either buy one off of Newman (he still has a half dozen or so laying around his barn) or get in touch with his wife and she will give you one for free, crate it up and pay the shipping costs.
Old May 26th, 2015, 11:18 PM
Well, whatever it is, you will need to take the engine apart to make it go away. So you may as well do that and see the condition inside. Or you can follow a logical test and diagnose procedure starting with simplest and cheapest items and eventually leading to tear down if necessary.
See if you can isolate the sound to one or more cylinders. Check your compression and your injectors and pump, and send some oil off for analysis. Then, depending on the results you can pull the head and oil pan and make some inspection, etc etc.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old May 26th, 2015, 11:38 PM
DefenderMd's Avatar
DefenderMd
Ben
有用极了人情
nah... slick 50
Old May 26th, 2015, 11:46 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Take the head off, use the same method as torquing it down, but reverse. I took the head off my 200tdi that way 3 times so far and brought it to a machine shop to check for straightness, and it was spot on. Let the engine cool down and take your time. Doesn't sound much like a hotspot (had a 2.5td with that problem). Check the injectors first and rockers/valves, might find the culprit without having to take the head off. Oil sample for analyst would greatly help but, worth chopping off the oil filter and check for particles. Not carbon! You can use a magnet to verify. Whatever it is you will soon find it out.
Good luck!
Old May 27th, 2015, 02:06 AM
Ignotus
gene
1960 109, w/200TDI
Listened to the video, that is a weird one sounds like a capacitor discharge spark kinda thing. Also sounded more external than internal. Is the grumpkin properly connected to the fibbertyjibbet? ;^)
Gene
1960 109
1960 88 Ignotus
Blog;
Old May 27th, 2015, 06:47 AM
1of40's Avatar
1of40
1of40
Originally Posted by DefenderMd View Post
Sounds very similar to what I had going on in mine a few months back. Ultimately I punted and decided not to make any additional investment in the NAD so unfortunately I'm not really certain what was wrong but from my readings of the symptoms I had lead me to think the failing hot spot was likely.
Old May 27th, 2015, 06:08 PM
DefenderMd's Avatar
DefenderMd
Ben
it does seem like that would be a most likely culprit. I still can't figure out where its coming from.
Old May 27th, 2015, 07:33 PM
It's a diesel. Clank tick tock clunk clank bag o nails...
Old May 27th, 2015, 07:41 PM
DefenderMd's Avatar
DefenderMd
Ben
Oh it doesn't have to be. It has to be loud.. but can be smooth.
diesel
Ticking noise from steering columb or dash... Drjeggle Defender Technical Discussions 3 June 19th, 2013 06:28 AM
Ticking noise. Oil pump? ini88 Defender Technical Discussions 11 November 25th, 2009 07:12 PM
Ticking? Flagg Misc. Chit-Chat 16 March 16th, 2009 12:15 PM
AC compressor ticking artm Defender Technical Discussions 2 March 2nd, 2007 01:19 PM
Ticking noise at idle thug1313 Defender Technical Discussions 11 March 10th, 2005 11:20 AM
