Iron Goat dash? - Defender Source
Old August 7th, 2006, 07:09 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Iron Goat dash?
Anybody try one of these? It looks like a neat way to add switches and a couple of extra gauges.
http://www.ig4x4.com/cat1_1.htm
Old August 7th, 2006, 09:00 PM
I got one. haven't installed it yet. I'll take pics when I'm done. looks awesome though. the switches are from the same manufacturer as the ARB switches. If you go to the switch manufacturer site, you can swap out the rocker cover with a logoed rocker for almost any function.
Old August 7th, 2006, 09:21 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Actually I think we'd like to see some pics of the installation - especially after you trim the lower dash panel but before you put the new panel on. I'm wondering how much of the cowl vents it blocks too.
The whole thing looks like it should be pretty sturdy - I'm probably going to get one too but I'd welcome the evaluation of a "first guinea pig".
Old August 7th, 2006, 11:01 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
That looks totally sweet--I think I may get one...but I will probably put my CB where the stereo is...
Old August 10th, 2006, 04:46 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
One thing . . .
They don't mention this until you read the instructions, but it is necessary to bend the shifter in order to clear the front the new dash panel without your hand hitting it (at least on a manual transmission).
I bought one off ebay about a mont ago and will be installing it soon (I hope).
Definitely agree that it is a good spot for a CB.
I will try to post some pics if/when it happens.
Greg.
Old September 28th, 2007, 12:15 PM
Here is mine installed. I don't think Pendy had to bend the shifter. nothing close to hitting. Still need to get gauges and assign the switches.
Old September 28th, 2007, 01:38 PM
Mighty's Avatar
Mighty
mighty
epsom 110 & stornoway 90
Mark,
Is that the new style LR GENUINE AC installed in your 110? If so, where did you get it?
thx
S
Old September 28th, 2007, 01:39 PM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
Mark, that IG looks great! Oh, the decisions b/t that and the Mudd UK. Why did you choose the IG over the Mudd?
Old September 28th, 2007, 01:54 PM
S, it is the new style LR A/C. M&D Engineering bought it on my behalf and through it in the crate with my 2.8 (that's a nice xmas gift combo isn't it?). It's made for LR by a company called CoolAir in the UK, and I have the contact #. Same one sold by RN.
Andrew,
I went with the Goat the moment I found it. MuddUK version came out several months later.
Old September 28th, 2007, 01:58 PM
Mighty's Avatar
Mighty
mighty
mark,
pm sent.
thanks
S
Old September 28th, 2007, 02:12 PM
For all. CoolAir UK contact is Reg Ford. reg.ford@coolairuk.ltd.uk
He is the most email responsive fellow I have worked with yet from the UK.
Old September 28th, 2007, 09:42 PM
lrnasd90's Avatar
lrnasd90
J. Landers
1983 110 LHD Galvanized Everything
rds sells complete a/c kits as well, I bought one from him for my 300 tdi.
Oh and I install that IG dash and I had to bend the shift lever a bit. I don't think it would rub, but it was closer than I wanted. I really like the setup.
Old September 29th, 2007, 06:55 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
I just finished installing mine (had to have the new stereo for the trip to MAR) - still need to wire a few things up but its functional enough for the trip to Virginia and back.
I didn't have to bend the shift lever at all.
dash
Iron Goat Dash CDeWan Defender Technical Discussions 16 September 3rd, 2013 10:30 AM
Iron Goat Dash AggieD90 For Sale - Parts 3 January 14th, 2009 10:59 AM
Iron Goat Door Panels CDeWan The Flea Market 0 September 22nd, 2008 02:01 PM
Iron Goat Dash with CB Bozman Smaller Projects 16 July 31st, 2008 08:30 AM
Iron Goat Dash Overlander For Sale - Parts 5 February 21st, 2008 11:54 AM
