IR Temp Gun Readings - Defender Source
Old February 2nd, 2015, 05:24 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
I was having some issues with my OEM temp gauge and installed a VDO gauge today. I also purchased an IR temp gun to confirm my temp to ensure the gauge was working as it should. On a 300tdi where is the most accuarate place to get a reading and how far off off the location are you holding your gun? Right now I am averaging 10 degrees cooler from the gun reading than what the gauge states (Gauge reading warmer).
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
1971 109 3 Door (Sold)
Old February 2nd, 2015, 05:30 PM
Id shoot the casting right next to the sensor for the gauge to know how far off the two are. Then try the water outlet elbow (where the top radiator hose connects). In theory that elbow should be the highest temp of your cooling system.
Old February 2nd, 2015, 06:01 PM
sloanfiske's Avatar
sloanfiske
Anthony Nelson
Same issue I've had. Apparently it's common.
Check the thread VDO temp sensor issue I started a couple months ago.
Old February 2nd, 2015, 06:08 PM
http://www.defendersource.com/forum/...ad.php?t=55393
Old February 2nd, 2015, 06:25 PM
Along these lines...what is the temperature "loss" from where the sender threads in internally (i.e. where the sender tip is) and the outside of the casting? Isn't there - in theory - some temperature loss either across the sender (i.e. if you're measuring the outside terminal versus the inside "tip" of the sender), and the same with the casting?
I was wondering about this as well, since I too was thinking mine was running "warm"...but what I would see at the gauge as 190* would be 170* @ sender, 173* @ the stat housing, and 189* @ the elbow. While I was more comfortable with this, I still wasn't convinced that the sender wasn't measuring a more accurate internal temperature, while I was in essence measuring the external temperature.
I also tested the ohms reading of the sender (per VDO specs that they sent me), and that did match up with what the gauge was reading. Which made me think even more that there is a loss of temp across the material(s) from the internal temp to the external temp.
Old February 2nd, 2015, 06:33 PM
If we want to geek out thermodynamically this could turn into an old fashion math orgy but...... once the entire cooling system is up to temp the difference would be negligible between the actual probe and the sensor body.
Old February 2nd, 2015, 06:35 PM
That is good to know...so looks like I'm up against what seems to be the "norm" of a 20* difference between the IR gun (a nice Fluke) and what the VDO reads. I'll try a fresh dedicated ground wire as recommended and see how that works out.
Old February 2nd, 2015, 06:42 PM
The VDO temp sensor is imbedded in the brass housing so it is actually reading the brass temp and not the actual coolant temp.
Old February 2nd, 2015, 06:44 PM
DannyboyUpstate's Avatar
DannyboyUpstate
Danny Harrington
1983 110 3-door
I use infrared temperature meters at work all the time. You have to be careful sometimes when you shoot something shiny, it will throw off the reading.
Also my VDO gauge was all over the place until I replaced my engine ground. Now the readings are solid as a rock. I don't care if the reading is accurate, I just want to make sure I can see the big changes.
Old February 2nd, 2015, 06:49 PM
Yah, keep in mind IR readings are not that accurate. They need to be calibrated for each surface.
Old February 2nd, 2015, 06:56 PM
One is meant to read the actual coolant temp, the other is the surrounding casting. Obviously, one can quickly change the other is slow to change.
Old February 2nd, 2015, 07:05 PM
emissivity of the material being measured makes a big difference
Old February 2nd, 2015, 07:15 PM
I'm pretty sure this is what I was trying to say. But i said it in English .
Old February 2nd, 2015, 07:17 PM
What you recon it is at the back of the block
Old February 2nd, 2015, 09:43 PM
sloanfiske's Avatar
sloanfiske
Anthony Nelson
I ran a dedicated ground with no change. Let me know if it works for you and where you planted the ground as I'll try again at some point.
I've gotten used to the 10* or so difference now. I know it's not overheating for sure.
Old February 2nd, 2015, 09:48 PM
Will do. My main concern is the voice in the back of my head that keeps telling me the gauge is right, and the IR reading could be off or there is a loss of temp across the material from inside to outside.
The one definitive tell would be to tap a mechanical gauge in the system to get a real true internal reading.
Old February 2nd, 2015, 10:04 PM
It's a motor, not a nuclear reactor. 10 degrees isn't going to hurt anything since you know which way hotter or colder it reads. It's also a hell of a lot more accurate that the original gauge.
sloanfiske's Avatar
sloanfiske
Anthony Nelson
Will do. My main concern is the voice in the back of my head that keeps telling me the gauge is right, and the IR reading could be off or there is a loss of temp across the material from inside to outside. The one definitive tell would be to tap a mechanical gauge in the system to get a real true internal reading.
I've got a 97 NAS V8, so I'm able to hook up the obd2 scanner to get the engine temp reading. It's always about 10 degrees cooler than what's on the gauge.
It's a bit of "horseshoes and hand grenades" right now.
Old February 2nd, 2015, 10:05 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
On your IR gun, does it indicate the accuracy range ? Many are +/-5F.
Mine is +/- 2F.
Old February 3rd, 2015, 09:24 AM
yeah, basically it has nothing to do with thermodynamics. different materials have different surface emissivities. the temp gun has no idea what you are pointing at, so it assumes some calibrated emissivity. this is why temp measurements differ.
False Gauge Readings Shearpin Defender Technical Discussions 1 August 18th, 2008 11:17 PM
Gun nut test Rod Hayward Misc. Chit-Chat 9 January 12th, 2008 11:20 PM
Unusual oil pressure readings. bomilcar Defender Technical Discussions 3 October 30th, 2007 05:53 PM
OEM Land Rover Gun Box RFA Wanted 4 February 20th, 2005 09:14 PM
rivnut gun mattdh Defender Technical Discussions 6 March 30th, 2004 06:46 PM
