Some folks say it is approved and some say it isn't. There are folks in the US with the engine. You can get the engine from Brasil for under $3k (brand new).
Mike - If by "approved by the EPA" you mean type-approved for installation into a Defender, the answer is a resounding "no."
If you mean "does the engine have an eligibility number" then they answer is maybe. Lots of engines have been tested or submitted for approval by manufacturers that they never intend to market or may intend to market at some point.
Now the thing is that it doesnt matter. You can import disembodied engines all you like because they are simply auto parts. For private owners, local jurisdictions are the enforcement agencies for the legality of engine swapping - since you are in NY (with their CA-like regs) you may have trouble convincing the authorities that a swap is legit. Of course NY may have provisions you could exploit, but I dont know. Your best bet is to join the military, that way you never have to live in your local jurisdiction.
The engine is not approved by the EPA. I have a friend that runs the parts department at an International dealership. I got him to do some checking around for me about getting a deal on a 2.8. He said that he couldn't get any info on the engine from US sources as they were not being brought into the US by International, and International had no intentions of bringing the engine to the US. So, International has never had the engine tested by the EPA. If you are worried about emissions testing, the 2.8 should pass with no problems, as I believe it meets the new Euro specs for emissions.
When it's time to replace my engine, this is what I want... brand new. Where in BRAZIL can this be imported for $3k ??
They had an International Engine Display... huge 18wheelers with cut-away engines to display, the whole nine-yards at the local Home Depot a few weeks back where I live... I had asked them about this engine but NONE of them had any idea.
Once engine is 'got' , then I need to find someone to put it in.
Another adventure.
I'm not worried about regulations, etc... this is Florida and unlike my native Garden State, this is a cakewalk... no emissions. The only bad thing is that there's no ECR, or anyone with a reputation down here that I could blindly give that kind of cash to and not worry. Unless any of you southern fella's have any ideas.
As long as you get all the correct parts for doing the swap, it's not that hard to do, just time consuming. John, where can I get one of those engines for cheap? The only person I know of selling just the engines is Stephen Cahill, for about $4500 + shipping. I would love to have one to replace the 300 in my SW if I ever had to :>)
Once you have have a 300 already, the only real difference is the Turbo between the two engines. Just buy one from Pendy and you are there. Move to Cali, they never smog any Diesel engine so it doesn't matter
Here some results from Holland.
We know that the engine manufacturer is in Brasil, but they do that not only for their own market they als built engines for Perkins and ....Ford, so what will bring the near future for you in the USA?
Further deliver International the engines for many years for the Land Rover Tdi.
The International HS 2.8 TGV has a power increase of opprox. 20% and torque increase of approx. 30% compared with the 300Tdi engine, that means faster than the standard TD5 engine by the same fuel consumption.
In Holland the engine is on the market for an 300 Tdi-engine swap and is complete delivered with injection-/pump , fuel pump, dynamo, waterpump starter engine flywheel steeringpump.
You need a extra built-in set such as modified exhaust pipe adaptor for remote oil filter ( in conflict with engine mounting. All can be done in approx 2 days.
A 200 TDi is more difficult; the engine must be replaced to the front, next to the basic set you need 52 more other pieces for replaced gearbox/ clutch radiator intercooler.
All with instruction manual, probably in Dutch.......and now the most important thing price
engine complete HS 2.8 GTV Euro 5.000,-- multiply by approx. 1.35
mounting set 300 Tdi 375,--
mountingset 200 Tdi 2.100,--
I found this information on a dutch website so I translated it a bit .
Is there anyone out there who has personal experience with either the HS2.8 or warmed over 300 TDI in a heavy 110 running 35's or larger? I originally planned to put the 300 TDI in my truck, but was sidetracked by the EPA issues and also a concern about a little 4 cylinder having enough power. But the specs of the HS2.8 are impressive, and I'd love to get even better mileage than I do now.
That's a very cool truck, but I was thinking more of an expedition-type 110. Something that has to perform on-road as well as off. I think the small engines can be geared to work well offroad, but are they practical on the highway as well? I've put ~50K miles on my 110 in about 2 years so overall capability is really important. And all the miles is another reason I'd like to improve my fuel mileage even more (the 6.5 is getting 15-18 mpg).
Once you tweak a 300 it has enough power. I have 37's and run a full cage and a hardtop. It is faster off the line than any factory Rover V8. I can peel out on a dry street with all fours with this engine and the bigger tires. It can do 80 all day long but I don't like where it is revving at. I might switch t-cases. It is a good work horse and I can not complain about the 28mpg or the light weight for a Diesel. 2.8 would be better if it can be tweaked but I have more power now than a stock 2.8.
Not to trash anyone, but about a year ago I spoke to Disco-tech about the engine, I think his name was Chris. There was a price on the web site and he confirmed it. When I was ready to order about 2 weeks later, everything changed about $2000 more. I asked around and was told he gets everything from M & D in the UK and that he wasn't very knowledgable about the install or kit. I have been in touch with M & D based on recomendations from people who had bought from them. They are very helpful, friendly and most of all knowledgable. Either you go the chepest route and buy from International and build your own kit over the course of a year + or do it the right way and buy from M & D and get everything in one shot. The last time I spoke to M & D, the pound was a bit softer and a complete kit with upgraded radiator, shipped was about $11,000.
I hope this doesn't trash anyone either but some skrew has to be loose to pay $11,000 for this motor. You could drive your truck over to a Diesel Specialist, throw them the keys and come back 2 weeks later and pick up your truck with a brand new Cummings Turbo Diesel all for $10,000. My 300 was a net $3000 total with the transmission, new clutch, and t-case and I would not pay more than 5k for everything. This motor is great, but not worth more than that. Lets do the math:
Tweaked 300TDi = 150 hp @ $3600 (motor and drivetrain, used new intercooler)
Stock 2.8 (might be able to tweak it) = 136 hp @ $5000 (motor only new)
Stock Cumming Turbo Diesel V8 = 350 hp @ $10,000 (new, installed)
Stock 2.8 (might be able to tweak it) = 136 hp @ $11,000 (motor only new - but people knowledgable)
Related Threads
Defender Source Forum
1M posts
24K members
Since 2003
