International HS2.8L - Page 12 - Defender Source
Old February 15th, 2006, 01:52 PM
OBW_Canada
Stephen Cahill
Hello David check your Email
Originally Posted by dmarchand
Yeah, I have a hard time buying it. The 2.8 service manual says max oopening of the thermostat happens at 216 degrees. Seems like a long way from 230+. Do you have this in writing from them?
Hello David am sending you the doc file on comparisons of the 3 engines. Remember that temp is with the system pressurised to 18 PSI.
Old February 15th, 2006, 02:28 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Got it, thanks. Although www.convertme.com is probably not a good link...
I'm surprised to see it at 230. I've seen 220 and it scared me. I guess I need a boost gauge to get a better idea of where I stand.
Old February 15th, 2006, 03:13 PM
OBW_Canada
Stephen Cahill
Hello David
Sorry that link should be
http://www.convert-me.com/en/
You may want to look into
http://www.evanscooling.com/
It is said it does not like cold weather though.
Stephen
Old February 15th, 2006, 03:30 PM
Hey Stephen - LRM sez that the 300tdi has dropped out of production now - is this true? If so, then anyone wanting a _new_ engine will have to go with a 2.8 unless a NOS 300 can be found.
Old February 15th, 2006, 04:26 PM
OBW_Canada
Stephen Cahill
Hello Jim Re 300TDI
Hello Jim
If it is out of production it is news to me.I just got new pricing on them last month. Will ask in the morning as I have to call on another matter.I have the calendar of what is being built for the next 6 months at the different factories in South America.Will have to look to make sure. The difference in cost of a new 300TDI and a new 2.8 TGV is only 300.00 USD.(through our company) You could always go for the I6 but who needs 185 HP.
If you want to keep abreast of the developments on the South American diesels our new web site
www.obwcanada.com
has a forum for that. With the adapters for the 2.8 TGV it can be used in close to 50 different models of vehicles things are a bit busy.
Stephen
Old February 16th, 2006, 10:31 AM
Michael
Michael
Discovery 1998
Gauges and Senders:
What gauges are compatible with the stock water temp sender on the HS2.8L?
Stock Trans Temp (ZF auto)?
Old February 16th, 2006, 10:52 AM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
Hey Michael... what ever happened with your engine? You've been pretty quite.
I used all VDO Vision gauges, replaced all my gauges for continuity. I like the new gauges, very clean looking and they all work very well. The programmable speedo makes things easy.
Originally Posted by MuddyOval
Sheki, you are a wang too.
A wang is another word for, you guessed it, A DICK!
Nothing racist, just pure DICK!
Old February 16th, 2006, 11:13 AM
Michael
Michael
Discovery 1998
Hi David. Thanks for asking. Very humbling exerience. But that Espar does sound like a jet engine! I almost sh*& myself when I first ran it, and told everyone to evacuate the house!
One of the cylinders (#3) has very low compression (about 100 psi). We don't know exactly what is causing the low compression yet as I have decided to delay working on this until the springtime.
Something definetly blew in the oil circuit as the water cooling circuit was heavily contaminated with engine oil - whether it's just head gasket is uknown. I will post info when I know
In the meantime, I opted to get a second engine (ouch - had to take a loan out) after M&D gave me a good deal on it due to the circumstances.
I am surprised that the whole factory workshop manually does not stress the importance of the oil level.
Old February 16th, 2006, 11:20 AM
sheki's Avatar
sheki
David Shechter
Sorry to hear about the trouble; however, I'm glad you are persevering. I suppose someone will get a good deal on a very slightly used diesel engine. You should contact Pendy, I know he is interested in sticking one in a P38 RR.
Those Espar heater are awesome! Pendy and I too were freaked when we turned that thing on for the first time. Even more so because it was smoking from being fired up for the first time.
Old February 16th, 2006, 11:28 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
You can use VDO for the trans. Only problem is their guage goes to 400+ degrees. I think if a ZF ever sees that, it's baked. So it's not a great gauge as the temp is always low and hard to read.
Are you planning on towing anything?
Old February 16th, 2006, 11:38 AM
Michael
Michael
Discovery 1998
David: It sound like the VDO gauges can be hooked right to existing senders. Is this what you meant?
Thanks.
Old February 16th, 2006, 11:45 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
if its like the 300tdi, you have to order the sender also which is just a direct replacement for the stock sender. it screws right in. THe VDO is nice and acurate and shows actual temp not like the LR gauge with the H and C on it... I still want to hook up an EGT gauge one day.
Legend in My Own Mind.
Old February 16th, 2006, 11:59 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Sorry, definitely use the VDO senders.
Old February 16th, 2006, 12:00 PM
OBW_Canada
Stephen Cahill
Hello Micheal
The engines are normally shipped with the Ford version of the oil sump and oil pickup and the oil in it to run for the break-in period. When you put the engine in the truck you checked the oil and saw what on the stick? Can you state what were the instructions on lube oil levels with a different oil sump on the engine?
As for the factory manual the online version states the oil is to be checked every day.
http://www.nav-international.com.br/Manual.asp?Idioma=2
There are 3 other things to be checked daily.
The parts manual is there also.
With the adapters for the 2.8 to the GM line of transmissions it opens up a huge collection of vehicles to this diesel engine.
Let us know if you want a quote on parts to rebuild it.
Stephen Cahill
www.obwcanada.com
Old February 16th, 2006, 12:14 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Thanks.
No new sender. 1/8" pipe. Cost is very reasonable on these items at egauges.com
I am interested in your engine. And I could come collect the whole mess and sort it out for you if you like. Shipping to me is less costly. Loves duty and broker fees were 199.00, no extra charges with door to door shipping from M&D.
Originally Posted by OBW_Canada
This is from engineering in South America.
Cooling system
Max. Continuous water temp.230F.
Max. Intermittent water temp.248F.
I do not accept this. I have been aware of those specifications for a couple years. It reminds me of when they used to make the engine without glow plugs. Another engineering debacle. Your armchair analysis is unrealistic about the cooling system needed for the more demanding of these engine installations.
When I am happy with my resolution you are welcome to critique it. It is nice to hear your reports from the engineering people associated with the eingine. But realworld experience overshadows everything from the drafting room, in my opinion. I would like to hear some warantee repair tickets quoted on this engine installed in the Ford Ranger in S. America. That would mean more to me then engineering specfications.
JP
legend in my own mind
Old February 16th, 2006, 12:41 PM
Michael
Michael
Discovery 1998
Regarding Oil Level:
Where does it say: "CAUTION or WARNING" : Do not overfill or engine oil may enter combustion chamber and may cause engine to run out of control causing severe engine damage?
Every internal combustion Engine Manual ever printed on ths planet probably says to check oil level every day.
Old February 16th, 2006, 12:57 PM
OBW_Canada
Stephen Cahill
Jim you having a bad day??
Do not $hit on me.
My reply is in bold.
Real world as you know the engine will take some heat for a while.Not that I would ever run one at that temp or suggest it be done. THAT IS WHY I DO NOT SUGGEST BOOSTING THE FUEL LEVELS.
I do not accept this. I have been aware of those specifications for a couple years. It reminds me of when they used to make the engine without glow plugs. Another engineering debacle. Now are you stating it is my fault they came with no glowplugs? They were OEM engines for BRAZIL and the rest of South America.Why put glow plugs in an engine where the coolest it gets in winter is 50 to 60 F.
Jim as you know the heat output is greater than the 300TDI so why would anyone ever use a 300TDI rad when they are known for over heating at the best of times? I have never suggested that a 300TDI or the HD version of it was the best to use.
When I am happy with my resolution you are welcome to critique it. It is nice to hear your reports from the engineering people associated with the eingine. But realworld experience overshadows everything from the drafting room, in my opinion. I would like to hear some warantee repair tickets quoted on this engine installed in the Ford Ranger in S. America. That would mean more to me then engineering.
specfications.
JP[/QUOTE]Jim you have questions for Ford of Brazil
https://www.ford.com.br/Default.asp
I have no contacts there sorry.
Now if you want to list questions for MWM-International warranty I can have them forwarded.
PS I left two voice messages on your phone about the mail I sent you last week.
Stephen
Old February 16th, 2006, 02:14 PM
artm
Arthur Maravelis
97 SW
"...why would anyone ever use a 300TDI rad when they are known for over heating at the best of times?"
Do you mean they easily overheat in a 300Tdi application? I don't think so. In my experience the only time it approached slightly higher than normal temps was on a 98-degree summer day with the AC on and heading up hills. Even then it was well below maximum. I am sure if I had a REAL radiator in there it would be no problem. The OEM is a little shit thing.
It always amazes me how difficult it SEEMS to get a proper cooling system in Rovers. How difficult can it be to install the biggest aluminum radiator that'll fit? If a '65 Corvette with a 396 V8 can EASILY cope then why wouldn't a 2.8 or whichever Rover V8?
I don't think it's a matter of physical space. So, what's the problem? Ditch the OEM crap and get a Summit aluminum job. Done! Why the need to make an OEM job work?
Old February 16th, 2006, 02:22 PM
OBW_Canada
Stephen Cahill
RE oil level AKA TOO MUCH OIL
Michael
I am very sorry about your engine problems. Now why vent at me? It was not my instructions you were using to install or have the engine installed. You pour 5 or 6 EXTRA quarts /liters of oil into any engine you gonna have problems. You made a mistake it seems.
Stephen
Old February 16th, 2006, 02:36 PM
artm
Arthur Maravelis
97 SW
I hope that wasn't a venting at you, Stephen. I find it amazing that no oil appeared on the dipstick before Michael added any. It is unfortunate that he was unaware of the existing oil level.I agree, there should be some sort of notice that there is oil in it - to cover the ignorants.
As for the runaway, a little reserach in diesels before taking the plunge would have made anyone aware of their "delicacies": be it filter changes, fuel quality, EGT's, proper startup/shutdown, etc..
That was one costly mistake - an installer's mistake.
Correct intercooler for International 2.8 engine Santiago Defender Technical Discussions 5 June 13th, 2008 04:12 PM
International MXT mauid90 Misc. Chit-Chat 1 June 19th, 2007 02:05 PM
FS International HS2.8L Michael For Sale - Parts 10 May 15th, 2007 09:17 AM
International HS2.8L Filters DesertRat Defender Technical Discussions 3 August 7th, 2006 11:51 PM
