Intermittent wiper issue - Defender Source
Old December 13th, 2007, 01:01 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
I noticed this morning that my intermittent function on the wipers does not work anymore. The wipers will work fine on full speed and the sprayer works, just not the intermittent setting. Does anyone know how to fix this??
Old December 13th, 2007, 02:43 PM
You've got a 95, so I think you've got an intermittent wiper relay located behind the fuse panel and IIRC, its red. This is probably either loose or dead. Its not hard to get to, you just have to unscrew the fuse panel from the firewall, unfortuately you dont have much play because of all the wires, but its an easy swap.
Old January 8th, 2008, 02:53 PM
Craigd's Avatar
Craigd
Craig Dickson
Jim,
Thanks for that info. I pulled off the fuse panel and sure enough there was a red box staring at me. I went on AB's web site and they had a red relay that looked the same. Bought it, plugged it in and now I am good as new. Knock on wood but that was probably the easiest thing I have ever fixed.
Wiper Park issue (only on normal/fast speed) rlynch356 Defender Technical Discussions 10 October 28th, 2009 09:07 AM
91 RRClassic intermittent stall-TPS issue? Ren Ching Defender Technical Discussions 6 December 29th, 2008 12:20 PM
What makes the Rear Wiper park? COSteve Defender Technical Discussions 10 March 6th, 2007 04:40 PM
Locating the rear wiper pepstein Defender Technical Discussions 0 April 2nd, 2005 09:56 AM
Wiper Blades going haywire... arbik Defender Technical Discussions 4 February 22nd, 2005 11:07 PM
