Intermittent Starting Problem - Defender Source
Old February 19th, 2011, 03:28 PM
Run110
Eric Thompson
'93 110
I've searched the threads and found many that have solved similar issues. I've put most of the recommendations in place, each time seeming to solve it for a couple months, then same symptom comes back.
When starting it will crank the engine but not fire. No spark. When it does happen, I can always start it with a roll and a compression start. Once going it runs great. Most of the time, after a compression start it will work fine on key start for a while, then one day no start again.
I've replaced the cap and rotor, plug wires, did the ignition module relo kit, replaced coil, replaced ignition switch and key.
Since it starts with key in the #2 spot on compression, but intermittently no spark in #3, it must be a short somewhere in the system? Short of replacing the wiring, what else should I focus in on that I haven't already done?
start, starting
Starting problem (occassionally) kolvedic Defender Technical Discussions 21 January 21st, 2012 11:12 AM
Intermittent Starting Problem 61rover Defender Technical Discussions 0 September 24th, 2010 01:50 PM
Interesting starting problem kolvedic Defender Technical Discussions 3 December 12th, 2008 06:12 PM
Help! Problem starting (95 SW) reaper99999 Defender Technical Discussions 8 March 2nd, 2006 07:22 PM
Random & Intermittent Fuel? Problem popeohana Defender Technical Discussions 2 July 18th, 2005 02:47 AM
» Defender Registry
90
uc4me
NEV
wanabewheelin
Add your Defender
