Intermittent stammer and fuel smell - Defender Source
Old March 7th, 2011, 09:11 PM
2yellowlabs's Avatar
2yellowlabs
Rob
92 RRC, 99 DII, 06 LR3, 09 LR2
So a month ago I replaced the ingnition amplifier module, the cap, the rotor, the vacuum advance (I knew it was bad), the plug wires and the vacuum lines thinking that one of these was causing a hot stall.
For a while it ran good, better even. Now I'm getting that stammer again under load. I drive long enough to warm it up (15-20 min) and it's usually after a period of driving in fourth approaching 3K rpm that I get the stammer. Feels like fuel starvation and then I smell gas. Letting off the accelerator and feathering the gas for a minute or two seems to keep it running and then all of a sudden it's gone. After that the truck runs fine the rest of the way to my destination.
I assume this issue is fuel related. So is it the fuel regulator, the fuel filter or the fuel pump?
What pressure should I have at the fuel rail?
Thanks!
Thank you -
Rob
Old March 7th, 2011, 10:39 PM
Is the gas cap holding pressure? Changed the fuel filter?
Originally Posted by pendy
I'm here for the D's
Old March 7th, 2011, 11:20 PM
2yellowlabs
Rob
Yes. No not yet.
Thank you -
Rob
Old March 9th, 2011, 10:27 PM
2yellowlabs
Rob
Exclamation
Bypassed the whole second gas tank switching valve set-up returning it to stock w/ a new fuel filter, checked pressure at regulator and even replaced coil. Still stalling out when warmed up. I've also replaced ign amp module, cap, rotor, wires, vacuum advance and all vacuum lines.
What the hell is causing this problem?!
ECU?
Thank you -
Rob
Old March 10th, 2011, 03:42 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Dirty MAF? Dirt in the fuel rail? Dirt in the fuel pump? Dirt in the tank clogging the fuel pickup? Leaky line from the tank? Leaky injector seals? Water in the fuel?
Stop replacing electrical components and do some diagnosis on the fuel supply.
Tony
1984 110 "Smokey" (sold)
Old March 10th, 2011, 08:17 AM
To be fair he has looked at the fuel supply. I'm not sure how you are checking the fuel pressure, but can you check when it's warmed up too? Maybe the fuel pump is failing.
Old March 10th, 2011, 09:39 AM
2yellowlabs
Rob
Checked the fuel pressure with a guage at the regulator when it was warm. Siphoned some gas from this location (after the filter) and there were no excess bubbles - indicative of fuel pump issues and no visible debris in the fuel. This truck has had some mods with an unfinished project - (by previos owners) ROW additional fuel tank added under the pass seat and a six way bypass valve with two fuel filters - all of which was removed last night. There are no leaks or water in the fuel.
All components replaced thusfar were suspect given age/condition and would have been replaced anyway.
Thank you -
Rob
fuel
