Intermittent Acceleration Failure ONLY from Stop -- 97 D90 - Defender Source
Old March 17th, 2009, 01:18 PM
pcscharfe
pcdefender
D90/NAS 110
Thumbs up Intermittent Acceleration Failure ONLY from Stop -- 97 D90
I have intermittent problems with acceleration from a stopped position. It happens at about every other stop. I first noticed the issue during an offroading trip. I have searched a variety of threads, but others seem to have similar issues under normal/high speed driving conditions.
Here’s how it feels:
From a stop, apply throttle, begins to accelerate for split a second, drops out completely for a second, then surges to catch up.
  • Only happens when the truck is stopped – never while cruising at speed.
  • Happens when engine is hot or cold
  • Happens at full or nearly empty tank
  • Since first noticing it, I have replaced the MAF sensor and both Cats (for unrelated codes thrown), and neither has had an effect.
  • I currently have no codes or warning lights on the system
  • Plugs and wires are less than 1 year old.
  • Fuel filter is less than 1 year old.
Possibly related issues?
Alternator was changed out about 3 months prior to first noticing problem.
Any ideas appreciated... Thanks!
Old March 17th, 2009, 02:31 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Sounds like a throttle position sensor to me.
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old March 17th, 2009, 02:35 PM
x2 to what eric said.
Old March 17th, 2009, 03:24 PM
pcscharfe
pcdefender
D90/NAS 110
Thumbs up
The Service Manual has some info on the TPS (below). My MIL has not illuminated, and idle does not appear to be effected, but the other symptoms seem to be in line with your suggestion.
Oddly enough, i have noticed a slight hesitation at the 1750 rpm range in the past.
Can i assume that if the sensor is on the fritz, it would create these symptoms and never trigger the MIL?
Throttle position (TP) sensor:
The throttle position sensor is mounted on the plenum chamber and connected directly to the throttle shaft. The sensor is a variable resistor, the signal from which (0-5V) informs the ECM of the actual position of the throttle disc.As there is no default strategy, failure of the sensor will result in poor idle and lack of throttle response. If failure occurs in the closed position the engine will only reach 1750rev/min when the ECM will initiate overrun fuel cutoff. The fault is indicated by illumination of the malfunction indicator light (MIL).
Old March 17th, 2009, 03:28 PM
"Can i assume that if the sensor is on the fritz, it would create these symptoms and never trigger the MIL?"
Yes. You can test the TPS with a scanner it should move linearly.
Old March 17th, 2009, 03:30 PM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
Mine used to do the same thing when I was on the interstate at cruising speed, the TPS had a dead spot and it would scare the crap out of me.
Old March 17th, 2009, 11:23 PM
pcscharfe
pcdefender
D90/NAS 110
Thumbs up
Thanks guys. I'll test the sensor and see what turns up... Anyone have a spare lying around that they want to sell?
Old March 18th, 2009, 12:07 AM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
I vote for the TPS. For some time I would get an intermittent TPS fault in my 95 SW. I would get hesitation sometimes just like you described. then one day, the truck would barely run at all, especially with a load on the engine. that is I could accelerate the engine in neutral, but when driving it ran so bad I turned around and limped home after about a mile. I replaced the TPS and it has run perfectly smooth since.
Old March 18th, 2009, 08:30 AM
Same issue for me on my Classic, TPS, my truck would cut out on the highway.
Old March 24th, 2009, 02:34 PM
pcscharfe
pcdefender
D90/NAS 110
Not the TPS
Brand new TPS arrived last night. Installed moments ago. Problem did NOT go away.
Any other thoughts?
Old March 24th, 2009, 02:37 PM
I give up.
Old March 24th, 2009, 02:45 PM
landrovered
S. Smith
Thinking....
Thinking...
Old March 24th, 2009, 02:48 PM
How about cleaning the butterfly on the intake?
Old March 24th, 2009, 03:31 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
I agree with Ron. Check the air intake hose for holes too.
Eric
Eric Riston
Old March 24th, 2009, 03:36 PM
pcscharfe
pcdefender
D90/NAS 110
OK. Will do.
The stepper motor has also come up in my research on the board. That's next on the list i guess...
Old March 24th, 2009, 05:17 PM
Grover's Avatar
Grover
Check the vacuum hose from the Plenum to the fuel pressure reg...
Old March 24th, 2009, 07:10 PM
xrover's Avatar
xrover
Len Cater
1997 D90
How about a weak throttle spring or weak overrun spring?
'97 D90 NAS
'06 Argo Avenger
Old March 24th, 2009, 08:00 PM
How many miles on the truck? I always thought the stepper would just cause idle problems? I thought a throttle spring would only close the throttle. Does it do it at WOT?
Old March 24th, 2009, 08:04 PM
pcscharfe
pcdefender
D90/NAS 110
32,000 miles on the truck.
The problem is only at the opening range of the throttle when starting from a stopped position. Not at any other time.
Old March 24th, 2009, 09:30 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Are your RPMs climbing without vehicle movement?
90, 97, 97 d90, ac, d90
headers for '97 D90 mdmccallum Defender Technical Discussions 43 April 25th, 2005 10:23 AM
I've Got A 97 D90 Frame That was just Galvanized ksteven Defender Technical Discussions 21 March 24th, 2005 11:22 AM
OEM MAF sensor from '97 D90.... dmarchand For Sale - Parts 4 June 18th, 2004 06:49 AM
97 D90 maxing out at ~70mph?? vnrover Defender Technical Discussions 3 November 10th, 2003 02:14 PM
For Sale: '97 D90 ST-1791 Alpine White jwebster For Sale - Vehicles 0 September 30th, 2003 12:36 AM
