Interesting starting problem - Defender Source
Old December 10th, 2008, 08:14 PM
kolvedic's Avatar
kolvedic
Bill Lewis
1995 White SW 339/500
So, I have had some intermittent starting problems. The usual stuff works fine: the pump runs, the fuel pressure is good, the spark seems ok. One day trying to figure it out, I disconnected one of the fuel injectors (farthest front on the drivers side) and it started right up with and engine light of course. I turned off the engine, reset the computer and started it up and off I go.
Had the same problem this morning, did this routine and the truck started right up. Drove it all day, had a problem again tonight, did the same thing and it worked.
I guess my question is: anyone know why this might work? do you think I might have a fuel injector going bad? Or maybe the compression is low on that cylinder?
I haven't been home to check my manual to see which of the injectors that one is.
More out of curiosity that anything.
l8r,
Bill Lewis
Bill
Old December 11th, 2008, 10:21 AM
Bill, I honestly don't know much about the EFI systems, but would love to hear what the problem is. Given your description I'd guess the fuel injector[s] are causing the ECU to decide not to start. Maybe lookup the specs for the resistance the fuel injectors should have, and check them all?
hth
charles
Old December 12th, 2008, 08:56 AM
xrover's Avatar
xrover
Len Cater
1997 D90
When it won't start, open the hood and check the throttle position. It is closed all the way? I had some issues and it ended up being a sticky throttle level, which was throwing off the throttle sensor position. After lubing it seemed to solve the problem.
'97 D90 NAS
'06 Argo Avenger
Old December 12th, 2008, 06:12 PM
kolvedic's Avatar
kolvedic
Bill Lewis
Thanks for the info. I will check that next time.
bill
Bill
start, starting
Starting problem (occassionally) kolvedic Defender Technical Discussions 21 January 21st, 2012 11:12 AM
Intermitent Starting Problem 97D90 Defender Technical Discussions 6 July 27th, 2006 08:19 PM
Help! Problem starting (95 SW) reaper99999 Defender Technical Discussions 8 March 2nd, 2006 07:22 PM
Interesting swivel ball problem dameek Defender Technical Discussions 1 July 24th, 2005 01:18 AM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
