Interesting leak - Defender Source
Old August 7th, 2006, 08:12 AM
johnnyg15
John Gorman
97 BRG Defender 90
Interesting leak
I took a flight to the adirondacks this weekend on Friday afternoon. I asked my brother to pick up the d90 at the airport for me the next morning. He said when he got there he saw a big puddle of red fluid under the truck near the front left of the truck. My first thought was transmission fluid, but too far forward. Then he said he couldn't turn the wheel when he went to move it. Then I thought power steering fluid. He left the truck where it was and I came home sunday. Sure enough the puddle was right where he said it. I had brought some power steering fluid with me and added it to the resevoir. I watched it overnight, the whole drive home and today as well. Not a drop leaked. If it was a small leak I wouldn't think anything of it. This was a very large amount of fluid and the resevoir was empty when I went to fill it. Any idea how this could happen and then not repeat itself? As an aside, I double checked the transmission fluid this morning and it is defintiely not that....
Old August 7th, 2006, 08:47 AM
Monkeyboy
Guest
Posts: n/a
So it was indeed low when you returned to the vehicle?
But hasn't leaked since ?
Old August 7th, 2006, 10:41 AM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
oil seal at the bottom of the PAS box, did you leave the vehicle with front wheels truned by any chance?
Old August 7th, 2006, 12:37 PM
johnnyg15
John Gorman
97 BRG Defender 90
Yes
It was indeed low when I returned to the vehicle. The truck was parked on a level sruface and the wheels were facing straight ahead. Weird, right?
Old August 7th, 2006, 01:12 PM
Maybe it over heated and bioled over? The fluid would need to get REAL hot to do that though.
Old August 7th, 2006, 01:46 PM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Well if he parked it at Newark it was 125 degrees in NJ last week.... 90 degrees normal weather and 35 dgrees due to radioactive material at the Newark port.....
John C.
New Leak d901560 Defender Technical Discussions 0 May 2nd, 2005 03:21 PM
Gas Boycott, interesting read draaronr Misc. Chit-Chat 7 April 7th, 2005 11:43 AM
Vacuum Leak Eric Siepmann Defender Technical Discussions 2 November 25th, 2004 09:11 PM
ATF Leak. What could it be? mdmccallum Defender Technical Discussions 2 September 22nd, 2004 09:08 PM
Exhaust leak dmarchand Defender Technical Discussions 12 February 4th, 2004 03:12 PM
