Interesting diesel facts - Defender Source
Old January 30th, 2013, 09:37 PM
gomotomoto
adam
Just today i read that some diesels can burn cooking oil if the ratio is right? So I figured post up and ask what's fact and fiction about diesels, specifically the ones found in the defender 110's.
Basically looking to learn any Other quirky facts and trivial things that make the Diesel engine unique.
Old January 30th, 2013, 09:45 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Compression is far higher than gasoline motors.
Old January 30th, 2013, 09:46 PM
Diesels were originally designed for farmers to run off plant oil.
Mark Kellgren
KM4BOR
Old January 30th, 2013, 09:49 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Diesel has more btu's than any other common fuel (natural gas, gasoline, propane etc)
Old January 30th, 2013, 09:59 PM
Michael110's Avatar
Michael110
Michael Dickin
1986 110 Tithonus - Now Sadly Sold
Back in the UK I ran a 200tdi 90 of a diesel/veg oil mix, 50/50 in winter, 30/70 in summer, ran fine no worries at all, just tipped it straight into the tank with the diesel. Im told you shouldnt try it with a Td5 though as the electronic injection system wont handle the change in fuel viscosity well.
Old January 30th, 2013, 10:02 PM
Where'd you typically score the veg oil from?
Old January 30th, 2013, 10:11 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
In France(Europe?), when gas/diesel price hits really high prices, some folks go to real cheap grocery stores (think Walmart or cheaper discount chains which you would not want to consider for food you would want to ingest unless you lost a stupid bet) and get veg oil in the larger jugs (the quart size takes too much time/effort to fill a tank, go one gal size at the minimum; 5L in France is decently common). Note that in France this is totally illegal.
Straight Veg oil works fine in the 2.5L engine for sure in the summer. Always help a little to mix with diesel for additive/anti-freeze agents in there (helps in the winter). I think I personally would have no problem using some in the 300Tdi. I'm not familiar enough with the Td5 or Td4 to provide any feedback.
Risks?
- gaskets go bad faster than planned (I'm not aware of anyone raising as an issue on the 2.5L/300Tdi)
- if temp is too low, then fuel is not liquid enough => pump has to work harder, might be causing premature wear => mix with diesel
- Might not burn correctly => higher emissions
I just Googled the risks, this seems fair: http://www.ehow.com/list_5783028_dis...oils-fuel.html
It's all about risk/rewards.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old January 30th, 2013, 10:13 PM
Michael110's Avatar
Michael110
Michael Dickin
I used to buy it new, while it was two thirds the price of diesel. I didn't have the space to set up a cleaner, but some guys were running used oil from takeaways, just have to be really careful to separate the water and hard fats out.
Old January 30th, 2013, 10:21 PM
JohnsD90's Avatar
JohnsD90
FYI the Veggie oil when burned smells pretty bad, far worse than diesel, had a 300td come in the scrapyard running it, i did not enjoy the smell at all.
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
It is highly recommended to convert your fuel system if you plan to run SVO (straight vegetable oil). Heated fuel lines are included in that conversion and plenty of companies offer conversions or kits. Personally I prefer the slightly more refined biodiesel, where virtually no conversion is needed (just make sure all fuel related hoses are synthetic). Biodiesel smells great
You should be able to get used vegetable oil from any fast food chain. They have to pay to dispose of it so shouldn't be a problem getting it donated. For $3500 you can get a biodiesel processor and start your own refinery at home:
http://www.evolutionbiodieselkits.com/
Old January 30th, 2013, 10:24 PM
This is where I make the strange confession that I don't mind the smell of diesel.
Old January 30th, 2013, 10:29 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
As good as cancer causing toxins can smell I guess. I've never smelled SVO but I love the smell of biodiesel. Smell like french fries. Makes me hungry
Old January 30th, 2013, 10:40 PM
Michael110's Avatar
Michael110
Michael Dickin
I never minded the smell of the diesel/veg oil mix, although I wouldn't recommend purposely inhaling either. Might depend on the type of veg oil of course, in the UK its mostly rapeseed oil.
Old January 31st, 2013, 02:36 AM
gomotomoto
adam
Just interested really, I don't plan on burning my deep frying oil.
Was curious what else to expect with my first diesel.
Old January 31st, 2013, 06:37 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
In the summer time I mix 50/50 SVO/diesel and I use 100% diesel in winter. Cuts down on bill and the smell ain't that bad. It all depends on where you get your SVO. Chinese restaurant will produce svo that smells Chinese and so on.. The only thing to consider is the waxing temperature for your svo. If it wax then your engine will stop as the filter will clog. Once you're in higher temperature you will not notice any difference from svo to diesel. Perhaps a small drop in power and a cheap restaurant smell!
Old January 31st, 2013, 08:14 AM
Viggen's Avatar
Viggen
Jarrod
none
Which is why it is more expensive than gas. It requires less refining but since it results in more btu energy, it is priced accordingly.
Old January 31st, 2013, 08:22 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Diesel has a higher tax rate also. At the Fed level its about $0.06 a gallon and it varies at the state level.
Old January 31st, 2013, 09:09 AM
bossman429's Avatar
bossman429
Adrian
1988 90
But it used to be cheaper. Which I don't get
Old January 31st, 2013, 09:21 AM
The Dro
Dro
1988 Ninety
The first diesel engine used peanut oil.
I have a buddy that scores it from Mc D, BB, and the likes for free.
He has a "process" plant to clean it.
It's a very kool project. I've been meaning to do this for the last 15 years.
You end up smelling like french fries.
Old January 31st, 2013, 09:49 AM
CMSgt Bo's Avatar
CMSgt Bo
Bo
1985 One Ten
Worn Diesel engines can go into a run-a-way condition:
http://youtu.be/5zx3qKX_Pno
Proud member of the YCHJCYA2PDTHFH club.
My mechanic told me, "I couldn't repair your brakes, so I made your horn louder."
ac, diesel
More on diesel / manual conversions Delta95 Defender Technical Discussions 37 September 4th, 2008 11:31 AM
Ex-MOD 2.5 diesel 90 EndlessEarth4WD Misc. Chit-Chat 18 January 26th, 2006 01:34 PM
Calling All Diesel Tow Rig Owners ronward Misc. Chit-Chat 14 October 4th, 2005 08:17 AM
Can you fab a diesel exhaust like a V8 exhaust? solihul Defender Technical Discussions 8 September 7th, 2005 04:09 PM
shop going under, diesel engines artm Defender Technical Discussions 0 May 12th, 2005 04:36 PM
