Interco LTB vs. radials - Defender Source
Old February 9th, 2011, 09:32 AM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
I like the size of the 34x10.5x16 interco LTB, but have never run a bias ply tire. I know from reading that the off road ability will be great, but I can't find much about on road. Will they shake me to death on the highway? The defender is mostly used off road, but I do drive it to the trail, and back and forth to town every now and then. The LTB tires are sure a lot cheaper than SSR's, and they are one of the only tires you can get from interco right now.
Also looking for suggestions on other tires that will be 34 or 35 inch tire by 10.5 wide. I am not interested in going to a 12.5 wide tire.
That is why it is called a short cut. If it was easy it would just be "the way."
Old February 9th, 2011, 09:52 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
They are actually 33 inch tires at best. Awesome off road, much better than the SSR, but as horrible on road as expected. Flat spots in the morning, noisy as all hell and not good in the wet. A step down overall from the KM2's you are selling.
Old February 9th, 2011, 10:39 AM
Naplm00
Matthew
I had 35x12.50 Mickey Thompson baja claw radials on my F150. They were always round, never flatspotted. Quiet in relative terms for a mud tire at highway speed. They also lasted about 65k before they dry rotted out, they prob had another 15-20 k of meat on them. I rotated them often with the spare and they also never chunked when wheeling or mudding. Kept them at 38 PSI all the time even offroad and never towed with them
Thats being said my buddy had a F350 with superswamper TSL bias in 38s; they were loud as fuck on the highway and would rattle you to death in the morning...but he was usually pulling me out
Old February 9th, 2011, 10:56 AM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
I have searched and searched, and can't find any other 35x10.5.16 tires except the simmex. they are also bias ply. Am I missing something? Are there any suggestions for a narrow 35?
Old February 9th, 2011, 11:24 AM
Naplm00
Matthew
Michelin XCL/XZL 9.00x16? i think they are 36 in tall and 10.5 wide
Old February 9th, 2011, 01:33 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
that helps. how wide is the 315/75/16? anybody know? will they rub on 16x7 rims? they are the gcr nuggets, they are 4.25 back spacing.
Old February 9th, 2011, 01:51 PM
Ummmmm....... 315 mm...... 12.4"
Old February 9th, 2011, 04:17 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
I understand the conversion, but 35x12.5 are not all 12.5 inches wide. I was trying to figure the actual width. Anybody have the bfg km2 in this size 315/75/16 that can tell me the actual width?
Old February 9th, 2011, 04:57 PM
Naplm00
Matthew
If you lookup on their site they should list the actual tread width or "footprint"
Old February 9th, 2011, 06:04 PM
http://www.bfgoodrichtires.com/tire-...-t-a-km2-tires
LT315/75R16/D
34.8" diameter
12.3" width on 8.5" rim
On a 7" rim it will be a bit narrower.
Old February 9th, 2011, 06:17 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
Interco *was* making an SSR in the 35 x 10.5 x 16 flavor....
The SSR does pretty good off road. I think the biggest problem is that people do not air down. Going from 35psi to 20 psi is not enough. I usually only run 24 psi on the road, and down to about 10- 12 psi off road. Lower in the snow.
I also use these on my daily driver. My old boss used to get very good mileage out of his from constantly rotating and monitoring air pressure. I think they are the perfect blend.
What tree?
WTB: Interco Trxus MT 265/75/16 tparnell8 Wanted 0 April 1st, 2009 01:56 PM
5 each 35x10.5x16 Interco SSR's w/steel NATO's Cirbo For Sale - Parts 1 December 10th, 2007 08:12 PM
(4) Brand New 33x12.50x15 TSL Radials Ash For Sale - Parts 0 December 19th, 2005 10:40 PM
SSR's or TSL Radials NashvilleRedD90 Defender Technical Discussions 3 July 16th, 2005 08:36 AM
Interco TSL/Thornbirds NashvilleRedD90 Defender Technical Discussions 5 May 27th, 2005 08:12 AM
