intake/valley pan renewal - Page 2 - Defender Source
Old November 11th, 2005, 01:22 PM
thanks. I ordered all my stuff from Rovers North this am. I hope that they get it right........ I think the guys in the warehouse and shipping are all smoking the reefer
Old February 4th, 2006, 07:29 PM
what should i torque the valve covers too?
Old February 4th, 2006, 11:05 PM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
9Nm
Old August 3rd, 2007, 07:03 PM
Gore Ranger's Avatar
Gore Ranger
Jeff
1989 RRC
I have oil leaking out of my valve cover gasket on the passenger side (the easier to accesss side)
I plan on replacing them while the truck is on the shelf over the winter. Are there any other gaskets I should do at the same time? Nothing else appears to be leaking.
Thanks in advance.
Old August 3rd, 2007, 08:18 PM
might as well do both sides while you are at it. since youll have the plenum off you should probally on the intake manifold gasket also.
Oil Pan Re-seal- Hylomar or Right Stuff? Grover Defender Technical Discussions 7 October 1st, 2008 02:01 PM
upper Pan Hard rod bracket TDI Guy Wanted 10 April 17th, 2006 06:27 PM
Oil Pan Leak Eric Siepmann Defender Technical Discussions 11 May 25th, 2005 09:47 AM
Oil pan drain bolt size?? mspell Defender Technical Discussions 1 October 2nd, 2004 12:09 PM
